SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
SOURCE: nec dterm wont ring in
During an incoming call try holding the up arrow on the volume key. That is the only way I know to increase or decrease the volume of the ring. The phone might also be set on DND. in which case you have to Press feature dial the DND cancel code 69 press feature. If note look for you user guide here. http://www.neccare.com/cng/docs.nsf/Lib3?OpenView&Start=1&Count=100&Expand=6.13#6.13
SOURCE: I have a NEC Dterm Series II phone. I need to
This phone works on different NEC phone systems.Elite,IPK, 2000, 2400. Each speed dial code is different in each system. what system do you have
SOURCE: Setting up voicemail on nec Dterm Series i is a
call your home number from your new phone that you will be using, and it should have prompts on setting it up! Hope this helps!!!
SOURCE: cannot change time on my Xen IPK Dterm Series i
