Question about Nortel T7316E 2-Line Corded Phone
How do i login to voicemail - Nortel T7316E 2-Line Corded Phone
Norm Pearl
  • 108 Answers
Feature 981, then your password (default 0000)
Posted on Feb 02, 2015
Tracfone com login
Contact TracFone for information on resetting your Voicemail password.
Mark
Motorola Support
Jul 22, 2014 | Motorola Mobility TracFone 616960005841...
How do I change voicemail setup?
Login to you voicemail and listen to the prompts
Jul 23, 2013 | Mitel 5330e IP Phone 50006476
How do I turn off voicemail
Need to login to phone system and change programming.
Jan 16, 2013 | Mitel Computers & Internet
Voice mail password reset without current number mitel 5207 ip ph
What voicemail do you have? Login to admin mailbox or login to phone system if you have Embedded voicemail.
Dec 11, 2009 | Mitel 5207 IP Phone
How do I change our voicemail?
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System2.gif the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming.
Oct 02, 2009 | Lucent PARTNER18 Corded Phone
Toshiba 2020
If you login to the mailbox change the greeting number from 3 to greeting 1.
Tony
Ameritel
732.477.7733
Aug 27, 2009 | Toshiba DKT-2020 Corded Phone
Can't check voicemail.
Is the time and date correct? Your system could have lost it's programming.
Aug 05, 2009 | Avaya Lucent Partner 616 Phone
I am trying to change our company voicemail and the manual (with the company's contact info is, who we bought the phone from) has walked away. Is there a standard code for setting the main VM greeting?...
What Toshiba Voicemail system do you have? Is it a Toshiba or third party voicemail? Depending who setup you voicemail and what version you have. Mailbox 990 is the Intro greeting "thank you for calling xyz company". Mailbox 991 is the main greeting "press 1 for sales press 2 for tech support etc. If you have a toshiba Voicemail. Need to login to 990 and 991 (need to know passwords) Newer versions you can setup just 991 mailbox for both.
Nov 26, 2008 | Toshiba DKT 3010 Corded Phone
Mitel Superset 4001
From that phone dial voicemail pilot number. It will login to that exts. voicemail if not it doesn't have a voicemail box.
Oct 12, 2007 | Mitel Superset 4001 Corded Phone...
Norstar Norcom
What you have to do is 2 main steps. Most Norstars have your first name set as the id for extension. Next, login to the admin portion of the VM from a large display phone. The keys used to login to VM is as follows..."Feature Key" (this is the key on the phone that is grey in color, and has a little black globe in the center, the numbers "9,8,3" then the system will ask for a login, now, if your extensions are 2 digit based the login is "12000o" and ok, if you have 3 digit extensions the login is "1020000" and OK, if you have 4 digit extensions, then the login is "10020000" and OK. Once you are in, on the display you will see MBOX, AA OTHER. press MBOX. Then Change. Enter in your extension and proceed through the prompts. Make sure that your name is listed as Last name first, first name and that you are set to Y for directory. That is it.
May 15, 2007 | NorStar M7310 Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
37 people viewed this question
Top Nortel Lands Phones Experts
Marvin
Marvin
Rich Barnett
Level 1 Expert
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
