Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Why does a samsung un46d6900wf screen comes up then shuts down, double blinks six times.?
1 Related Answer
Anonymous
  • 184 Answers
SOURCE: My Samsung HdTv will not
Hello, You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, If you need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where. power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help to solve the problem
Posted on Aug 27, 2011
Samsung 46" D6900 led tv horizontal lines
This can be an issue with the Timing Control circuit board, but that is just an educated guess.
Jul 19, 2017 | Samsung Televison & Video
Sylvania LD320SS8A error code 3. Power LED blinks 3 times than shuts down.
Could be the DVD player. Make sure there is not a disk stuck in it.
(This is one reason why you shouldn't buy these kind of units... if one part breaks, it all breaks.)
Jun 11, 2014 | Sylvania Televison & Video
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Samsung HLS5087WX/XAA DPL shuts down after 30 - 60 seconds, 3 blinking lights
I beleive from what you have told me that most likely it is just a lamp issue, there are a lot of so called original equipment lamps and counterfit lamps on the market that will barely give you 1000 hours run time. When it comes to Television lamps cheeper is not better. Make certain to buy an original Samsung lamp, you should get about 3500 to 4000 hours from it. If you need further assistance or have questions please reply to continue.
Jul 27, 2012 | Samsung Televison & Video
My Samsung HdTv will not come back on. Only a small red light next to the power button is blinking. First it was blinking six times then five now six again. Model TXR3079 or 8WHKXXAA. Samsung hdtv...
Aug 27, 2011 | Samsung Televison & Video
Sony 40xbr800 wont turn on, sounds like it wants to fire up but the stand by light comes on and blinks about 6 times
Six blinks points to No Horizontal or raster. The uProcessor detects a problem and enters the self test function shutting down the main power supply.
Feb 17, 2011 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Wont turn on, six blinks of led.
Hiii... what type of your TV Set and the chassis number ? it is a Sony ?
IF six blikns incdicated :
No Horizontal (H STOP), no raster...
I hope hear from you soon
[Vrya]
e-mail : [email protected]
Mar 07, 2008 | Televison & Video
Overheating of 56 in projection screen, samsung
do you get any blinking lights? if so how many times and how many lights?
Dec 13, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 56" shuts off after 5 or 10 seconds see a checker board image before shutoff
When the set shuts down you need to see what lights are blinking. For example: Timer/ Temp/ lamp on the front panel. You should also count the number of times they blink and the sequence. Most DLP`s give an error code alerting the technician to check the balast, lamp, or fan etc. for malfunctions. Unfortunately I can not tell you exactly what is wrong given the current information. Howrver, the last Samsung I repaired for shutting down had a bad light engine.
Nov 29, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
