Emerson MW8102SS 1100 Watts Microwave Oven Logo
Question about Emerson MW8102SS 1100 Watts Microwave Oven
How do you replace fuse for emerson microwave mw8115ss
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Blown Fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Posted on Apr 01, 2008
Anonymous
  • 903 Answers
SOURCE: Emerson microwave mw8115ss
http://www.microwavecooking.com/Emerson_Microwave_Parts.htm
try here
Posted on Oct 24, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: mw8115ssw no power
There's no reset button, only a a hard reset. Unplug the unit for a minute or so. Then plug it back in and see if ti works.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing [email protected]
Posted on Jan 12, 2009
Anonymous
  • 234 Answers
SOURCE: Replace Emerson Microwave Ove Fuse
Most of the manufactory has put them in the back where the power cord comes in.
Posted on Mar 14, 2009
rhozel2010
romy sibug
  • 269 Answers
SOURCE: Emerson MW9111 will not heat- all timers & clock work
Hi! try checking the fuse that goes to the magnetron.
Posted on Sep 12, 2009
How do i get the back off my emerson microwave
Screws are probably on the bottom of the microwave - then the whole side and top come off - then you have access to the back - i doubt it has an internal fuse though! I presume you have checked the plug fuse.
Be very careful - microwaves generate a massive electrical output and will fry you in a second!
My emerson microwave will not power on
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open. Use the VOM
God bless you
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
The fan and light com on when the door is open and the carousel turns. When you close the door everything stops.
Check the door interlock switches, you may have a faulty switch or a blown fuse inside the microwave.
1helpful
My emerson mw8115ss is working but not heating up how do i change fuse
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
My Emerson MW8115SS microwave works but doesn't heat anything up, what could be wrong? And is it a easy fix?
Hi there.
Obviously it is "not working"
Could be an internal fuse or the activator is just finished.
Iceman.
Top Emerson Microwave Ovens Experts
David Shaub
Jaime Hernandez
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
