Question about Kenmore 62622 Microwave Oven
When -F6- error displays, the touch pads only response is a beep tone. Unit still cooks by just closing the door.
My Kenmore 665.6062200 microwave intermittently displays -F6-. When displaying -F6-, touchpad only responds with a beep. No command/number entry. However, the magnetron, blower fan, and interior light start/stop just by closing/opening the door. (No turntable rotation) When the -F6- error is not displaying, the unit works completely normal. Occasionally, the -F6- error condition will self correct over time, or after shutting the door.
Posted by James c on
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Kenmore microwave model 66569619992
The first three digits of your model number are 665, which means it was made by Whirlpool.
On a Whirlpool, F6 means a fault on the control board, such as a timing error or a shorted relay.
A shorted relay could mean it is running when it shouldn't. Pleased don't allow it to do that for more than a few seconds, or other serious damage could occur.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If it still fails, please leave it unplugged, and I would say you have a problem on your control panel assembly, which we repair for customers nationwide with our $39.95 service.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Posted on May 27, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave won't function.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Also see http://www.microwavedisplay.com/doorsw.txt
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Dec 08, 2008
Anonymous
SOURCE: kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Posted on Dec 17, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Posted on Jun 19, 2009
Mukesh Kumar
  • 3230 Answers
SOURCE: error code
F6 is a communication error. It is either a loose connection to the control board, or the control board is shot. They should have diagnosed this when they came out to fix it. Open it up, and look for loose connections.
good luck
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
I have have a 10 year old Kenmore Hood/Microwave combo built by Whirpool. I'm getting an F6 error code. What is the error code trying to tell me?
F6 —Microwave Relay Failure: Check the microwave relay.
The F6 error code which is flashing on your microwave refers to a faulty relay. However, I would suggest that you first try to run a diagnostic (which you may not be able to, but it is beneficial if it works). Here is how:
The microwave oven may be provided with a self diagnostic routine that can be operated through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door.
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed.
If you want to try to fix it your self, Always remember Electricity is dangerous and should be treated with respect.
Microwaves are very dangerous, they can still shock you even unplugged!!
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
Hope that helps.........
Jul 10, 2008 | Whirlpool Microwave Ovens
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
Maytag microwave going crazy
< - Let ME know your full model number from the tag and I can give you complete detailed instructions on how you or a friend can fix it.
"SE" means you have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Jan 05, 2014 | Microwave Ovens
Kenmore microwave model 721.80039700. microwave starts beeping on its own. Display screen displays 1 then 2 then 3 then 4 over a short period of time. key pad hs stopped working. cannot start of turn...
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
Feb 26, 2018 | Microwave Ovens
How to resolve the F6 E0 error code on the built-in Kitchenaid microwave oven? The unit was brand new and installed 2 and half years ago in my new house. One website mentions the description for this...
"F6" on a Whirlpool microwave means you have a shorted cook relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 26, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
KitchenAid kemc308kss0 Micro/Oven Combo Microwave: At the end of any cycle there is a four-tone beep that will continue to beep until KINGDOM COME until you either a. open the door b. press cancel. That is...
From page 7 of your owner's manual:
All Tones (combination oven models only)
All of the above tones are preset on, but can be turned off.
To Turn Off/On: Touch and hold STOP TIME for 5 seconds. A
tone will sound and “Snd oFF” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd on.”
Tone Volume
The volume is preset at high, but can be changed to low.
To Change: Touch and hold the number pad “7” for 5 seconds. A
tone will sound and “Snd Lo” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd HI.”
REMINDER TONES
The Timer and Timed Cooking reminder tones are preset on, but
can be turned off. Reminder tones do not include end-of-cycle
tones. On combination oven models, if “All Tones” have been
turned off, the reminder tones cannot be independently turned
on.
Timer
To Turn Tones Off/On: Touch and hold TIMER SET • START until
a tone sounds. Repeat to turn back on.
Timed Cooking (combination oven models only)
To Turn Tones Off/On: Touch and hold COOK TIME until a tone
sounds and the lower oven display returns to inactive mode
(blank). Repeat to turn back on.
Apr 26, 2010 | KitchenAid Microwave Ovens
Kenmore microwave
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Sep 09, 2008 | Microwave Ovens
Error code
good luck
Feb 16, 2008 | Kenmore 69682 Microwave Oven
Kenmore 62622 Microwave Oven Logo
74 people viewed this question
Top Kenmore Microwave Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
