Question about HP Computers & Internet
How can i get my 2go password back
I opened a 2go account with my phone and now i want to login in with my pc laptop but i have forgotten the password how do i retrieve it my username is wruth21
Posted by wruth peters on
Bludat Fray
    New Friend:
  • 28 Answers
There are some methods for you to reset it, just follow the info and have a try
Option 1: Use a password reset disk to reset lost password if you have created one before forgetting the password.
requirement: USB flash drive or floppy
time: a few minutes
Note: This password reset disk can be only created when you can log on with the lost windows password.
Option 2: use a freeware to crack lost windows admin password, then you can get back the password, like Ophcrack
requirement: download Ophcrack live CD,
time: more than i hour
Option 3; a high efficient and easy-to-use low affordable shareware, like Windows Password Recovery Tool, which can reset windows 7 password quickly and successfully.
Requirement: a bootable CD/DVD or USB flash drive.
Time: within a few minutes.
Steps:
Step 1: Download and install Windows Password Recovery Tool 3.0 in any available computer from http://www.windowspasswordsrecovery.com/windows-password-recovery-tool.html .
Step 2: Burn a bootable CD/DVD to remove lost Windows password. (or USB Flash drive)
Step 3: BIOS settings
Step 4: Recover forgotten Windows password with the burned CD/DVD (or USB Flash drive)
good luck
Posted on Jun 17, 2014
5 Related Answers
getbackwindo
  • 84 Answers
SOURCE: Forgot username for admin acc in windows xp
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Posted on Apr 22, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: user password lockout
Hard disk password is set from the BIOS. It is usually set in conjunction with the Power On Password. This password is stored on the EEPROM chip and is very difficult to crack - no backdoor passwords. It is used to prevent unauthorized access to the laptop and the data on the hard disk. Removing the hard disk and inserting it into another computer will not allow access to data without the HDD password.
yboyandrei
Francis Mark Arango
  • 828 Answers
SOURCE: ASUS EEE PC 4G Password recovery!
its all technician consultation and for me remove the CR2032 battery inside the laptop to reset the biois inside... or press F8 to go safe mode and remove the previous password to enter at administrator...
Posted on Jun 16, 2009
Anonymous
  • 30 Answers
SOURCE: forgotten password on my Acer eRecovery Management
If you fully formatted the hard drive then most probably you have cleaned the PQservice division which might had recovery data; you can check this with the help of Computer Management console in Windows. It is in Windowssystem32compmgmt.msc. Also check the Disk Management and see what partitions you still have. Acer eRecovery Management won’t work if there is no default partition i.e. There should be E or D partition in order to run it.
Try www.download.com Here you might find your required software or else you have to ask the supplier to fix this problem for you. Hope this helps!
Posted on Sep 07, 2009
calasico
SOURCE: i sent message to 2go
restart my password for me
Posted on Feb 03, 2011
2go login
call (414) 544-2826
May 03, 2013 | Computers & Internet
I lost the sim card i used in registering my 2go account.i want 2 change my password hw can i do it pls.
If you say you want to change your password, that means you know the default password. If you do, then login with it and you can change it from settings on your 2go page.
on the other hand, if you have forgotten your password, you can visit 2go website to request a new one.
May 07, 2012 | Google Computers & Internet
I forgot my 2go password and i need it urgently,pls.
am using a cellphone and i fogort my password and evrything. I want to register another account. Pls help
Sep 21, 2011 | Computers & Internet
I want to open a 2 go account
If you need it for your mobile, make sure your mobile is enabled for browsing. Visit >wap.2go.im on your moblie >Fill in the form >Download the application >Launch the application and start chatting
Sep 01, 2011 | Computers & Internet
Want to log in on 2go.com
You have to get registered (or Sign up) with 2go.com before you can log in.
If you are already registered and have forgotten user name and password then please contact Customer support of this site.
Aug 25, 2011 | Computers & Internet
Why can't i login my 2go account
Can't login my 2go account pls I nid to fix it immediately
Feb 15, 2011 | Nokia Lands Phones
My phone is refusing to login on 2go
Then you need to check the network settings of your phone and secure that the internet of your phone is working perfectly fine, that way your phone will be able to login on 2go. Ensure the browser is using the networks internet settings as the default settings, then you make sure that the login name and password are correct, be sure also that it is the Sim that was in the phone when you registered for 2go that is in the phone when you are trying to login, if not it will not login you account on 2go.
Hope this information helped you.
Jan 11, 2011 | Nokia 6500 Slide Cellular Phone
I have forgotten my 2go password
I have forgotten my 2go password. please send it to my phone number 2348164774087. Username- pwetimanuela.
Jan 11, 2011 | Lands Phones
Forgot password
there is always a cell on the motherboard, remove it and place it back, this will reset / finish all the passwords on the pc
Sep 22, 2010 | Acer Computers>Laptops Aspire 5610-2328 PC...
Computers & Internet Logo
90 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
