Question about Pride Mobility Products Pride Legend XL - 4 Wheel HD Scooter
How do you change the Speed pot on xl8?
I get 7 flashes as the error code on my xl8
Posted by Derek Sewell on
Paul Kim
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 199 Answers
Mechanic is the solution
Posted on Jun 16, 2014
My status light blinks 7 times on my pride scooter how do I fix it
Hi 7 flashes ( SPEED POT ERROR ) possible speed control pot ::: wig-wag. control lever ,is ,faulty or it's possible the computer (CONTROL BOX ,) is Faulty...Get in touch with pride mobility ,..www.pridemobility.com.au .. Cheers
Jan 14, 2017 | Pride Health & Beauty
On a celebrity x i turn key on led lights but as soon as you touch throttle it flash code 7 and does not move
Hi code 7 is a speed pot error CONTACT A PRIDE DEALER. www.pridemobility.com. or call (877)706-2032 cheers
Mar 20, 2016 | Pride Celebrity X 4-Wheel Electric Scooter...
Flashing code 1, 3 speed pot fault
Usually turning the key off and removing it then re inserting the key and turning it back on without touching the paddle levers. If that doesn't fix it then the speed pot will need to be replaced.
Mar 16, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
What makes a speed pot go bad on a celebrity x 3 wheel scooter?
Yup you got a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pot is a variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should move gracefully up to 30k down to zero as the pot dial scooter speed increases. Failure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Jul 23, 2012 | Pride Health & Beauty
What makes the speed pot go bad on a 3 wheel celebrity x scooter
Yup you gt a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pt is aa variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should movee gracefully up to 30k down to zero as the pot dial scooter speed increases. Faaailure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Jul 23, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Hello, my scooter is fully charged, all the lights and horn are working. But it will not move forward or backward. The small green light flashes 7 times and stops for a while before flashing again. The...
outback you will have to get a new speed pot and replace the old one. Contact the provider where you got your scooter to see if they will fix it for you Hope this helps
Apr 16, 2011 | Health & Beauty
Go Go Scooter travels in reverse, but when going forward it comes to an abrupt stop every few seconds. Everything else appears to work normally. Any ideas?
csr4 Well it could be the throttle pot or the speed control pot My leanings is toward the throttle pot since it works in reverse with the speed pot not being changed but not forward. when you are just changing the position of the throttle to forward thereby changing the pot wiper and getting the error. Contact Pride about the problem at 1-800-800-8586 and ask for Tech support for scooters and explain your problem to them. I hope this helps
Oct 02, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Pride Mobility Products Pride Legend XL - 4 Wheel HD Scooter Logo
306 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
