Car Audio & Video Logo
A
Anonymous Posted on Jun 16, 2014
Ddx7037 hi, I have ddx 7037 kenwood. Is this unit possible to connect by 3.5mm jack audio? since i see AV In cable on the back unit. second one, I cannot found AV in or Aux in On this unit Source. hope you can help me. thankz Komang
5 Related Answers
otacon
Damen Wong
  • 1950 Answers
  • Posted on Dec 23, 2007
SOURCE: kenwood ddx 7019 password reset
It looks like the unit has a code programmed into it in the past. If this unit is second hand try contacting the previous owner for the code. If it's new from the shop, then contact the shop. The last option is to contact Kenwood and they can reset the code for you. Unfortunately there is no other way...
Anonymous
  • 111 Answers
  • Posted on Dec 24, 2007
SOURCE: Password Reset Help
During code request:
Point the remote control to the screen and input these numers (fast as you can).
55222277
ps.
You will not see any change on the display untill you enter tha last digit.
LET ME KNOW IF IT WORK thank you
hogan doan
hogan doan
  • 227 Answers
  • Posted on Mar 07, 2008
SOURCE: kenwood ddx-6019 password
Contact Keenwood, they may make you send it in and charge a fee. Goodluck.
Anonymous
  • Posted on Sep 28, 2008
SOURCE: forgot code for my kenwood ddx-7015 can u help
How Do I Reset my pass code?
Anonymous
  • Posted on May 07, 2009
a friend of mine who is into bypassing stuff...found this method from sumwhere and it worked on my system...
u need to reset the system first by pressing the small button right next to <ATT> using a ball point pen or something pointed... once it reboots, keep the <SRC> button pressed till the display goes off, then while keeping the <SRC> button pressed, press the <ATT> button for 3 seconds, while keeping both of these pressed at the same time, press the small <RESET> button next to the <ATT> button using something sharp... this hard resets the system and it reboots to a blank screen, press the <SRC> button once and you have all the options working...
anything else, lemme know... [email protected]
Ddx 419 no sound ipod
No offense but this is actually not the solution. There is a quirk with some Kenwood DDX 419. The manual on page 24 makes it clear that it is supposed to play audio through an ipod cable alone, only if you want to stream audio and video or the Garmin App should you need the other cable with the dual plugs (usb and audio). I bought one for my car and had it installed last week and it works right from the USB (only) with my iphone 4s and does not need the extra audio plug in which is inferior sound quality (analog) compared to the USB only (digital). I bought a second deck for my wife's car and had them install it this week and it did not work with the USB alone. The one on demo in Future shop did not work either with the USB alone. The manual for the DDX 419 makes it clear that it is supposed to stream audio without the extra cable. It reads, "To listen to the music (digital): USB Audio cable for iPod/iPhone-- KCA-iP102 (optional accessory). Look up the cable by google searching and you will see that even on the Kenwood site it is a regular iPod/iPhone cable. There is obviously a glitch with certain decks and they are not addressing it. I am returning mine and getting a Pioneer.
1helpful
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
1helpful
4answers
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
I can't get my PS2 to connect to my dual xdvd270
You can connect the PS2 Video out (composite video out) to any of the 2 monitors video connector and the audio at the audio connector, remember to select A/V ext (External Audio and video) both video and audio uses 3,5mm jacks, if it does not work you might need to try to draw out the jacks a little, the connectors are of poor quality so be carefull.
You also might want to check if the right system is selected PAL/NTSC, check the format from your PS2 and set the monitor to accept the same signal type, then it should work fine.
The only thing I am not sure how you do is to get the composite video out of the PS2 but study the manual or google and you will find it I guess, but my guess is that you allready have that part covered.
2helpful
No sound on ddx 514 kenwwod..when hooked up ipod to usb??
This is a faily simple fix. First of all, this USB will not be able to playback audio from an iPod or iPhone without using the correct cable. The cable needed has both USB and an audio plug on it. Here is a link to the Kenwood cable you will need:
http://www.kenwoodusa.com/Car_Entertainment/Accessories/KCA-iP200
If you would like playback of iPod video, you will need this cable:
http://www.kenwoodusa.com/Car_Entertainment/Accessories/KCA-iP301V
A local authorized Kenwood stereo dealer should have these in stock. I hope this information was helpful.
No sound on viewsonic VG730m
you have to connect it via audio cable.
you need a cable with two 3,5mm stereo jacks. this you have to connect with the stereo output of your computer (mostly the green one) with the audio jack on your monitor. it's somewhere on the back i think. sound / volume control you do in windows - its the same as if you connect normal stereo speakers to your computer.
(perhaps you have to unmute or to raise the volume in the monitors os menu)
Video output not working
it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
