Zenith DVP615 Portable DVD Player Logo
A
Anonymous Posted on Jun 15, 2014
Dvp615 not spinning - Zenith DVP615 Portable DVD Player
1helpful
Skips
This is not good, the problem is in the pladder motor that spins the dvd, it has become defective and will need to be replaced in order to correct the problem.
My dvp615 doesnt want to read any cd or dvd
Try using a dvd cleaner on the lens. If that does not work some people use a q-tip with a little rubbing alcohol on it. If niether of those work then the lens is not dirty but broken and will have to be replaced. Any other questionsjust give me a shout.
Zenith DVP615 backlight problem
Hi , for backlight
It DVD circuits will need to do servicing, as soldering , cleaning and should attach heat sink on the microprocessor, i guess.
Disk is not spinning in emerson portable dvd
if the disc doesn't spin, it sounds like a bad motor. can you hear the laser adjust? if you do, then it's probably a dead motor, if you can't hear that laser adjust at all, and the motor doesn't spin at all, the connection might have come undone(they both share a connection)
Check disc message
Sometimes the Spindel Comes lose from the Platter,Put one small drop of Super glue,Where the Center pin on the Platter is let dry for ! Hour,Should restore full operation...
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
