Why would the furnaces start running with the thermostat off ?
The blower will run with no heat if a high temp limit is opening, loosing power during heating demand, fault at control board, or if the furnace is still too warm from the previous cycle, it may bring on the blower only to cool it down. Now if it's heating with no demand, shorted control wire from t-stat to furnace, damaged t-stat, fault at control board in furnace.
Sounds like your thermostat is not working like it should. check to see if any wires are loose or broken
That doesn't sound good that the thermostat can be off, but the furnace will start. Mine is also acting up, but my furnace is making a lot of noise and not actually pumping out warm air. We should probably both find someone to repair ours. http://edgeguys.com/heating-services/
