Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Why is my Electrolux freezer outside walls hot
Roger Denney
    New Friend:
  • 3 Answers
The condensing coils are embedded in the walls of the freezer. The freezer uses the wall as a heat sink. This allows the freezer to dissipate the heat that has been pulled from inside the freezer to the area outside of the freezer.
Posted on Jun 16, 2014
1 Related Answer
ingrams
  • 22 Answers
SOURCE: walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Posted on Sep 08, 2009
My frezer is getting hot on the sides-why?
Its normal. The manufacturers got smart and put the condenser in the outside freezer walls. A lot of home refrigerators also have the same hot walls. Hope this helps good luck.
Oct 06, 2014 | Kenmore Freezers
Describe your FFU2124DW12 Problem The freezer works very good and gets very cold, But the outside walls and top gets EXTREMLY hot
Freezers have tubes that run inside the walls and top of the case, these carry the refrigerant thru the heat exchange process, this will cause the outsides and top of the freezer case to get warm/hot some times, this is normal, but I recommend you to make sure there is at least 1 1/2" of ventalation clearance around the entire freezer so that it can exchange heat efficiently.
If you don't think the amount of heat present at the outside of the freezer case is NORMAL, then I recommend contacting Frigidaire directly and discuss this with there customer service people.
1-(800)FRIGIDAIRE
GOOD LUCK !!
Aug 03, 2010 | Frigidaire Freezers
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Jan 01, 2010 | Freezers
Walls of freezer are hot to touch
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Oct 13, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezer problem
if you don't hear it running for extended periods of time (more than 15 minutes) without stopping, and if it does not immediately re-start once it does stop, and if it is extremely hot climate outside (85 F and above), then yes, this is acceptable.
Jun 08, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
407 people viewed this question
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
