Beverage-Air Freezer K Series Reach in Freezer 2 section 449 cuft Logo
Question about Beverage-Air Freezer K Series Reach in Freezer 2 section 449 cuft
My beverage air cooler keeps sound an alarm - Beverage-Air Freezer K Series Reach in Freezer 2 section 449 cuft
1 Related Answer
Dennis Boxerman
  • 1306 Answers
SOURCE: what are the minimum and
Most all manufacturers try to build units to hold between 34 to 38 degrees as this is the most commonly accepted range for coolers by all Health Departments.
Posted on Oct 06, 2010
What are the minimum and maximum operating temps for a beverage air sur72-30m prep table cooler?
2answers
Combination cooler/freezer will not get blow 30
a coil covered in ice is one of two things
your defrost is not working or your circ fan is not working
make sure the fan inside is free and spinning
the make sure your defrost timer is operational
the bev airs are usually right in front behind the toe kick
short of that ohm out your heater to ensure its working
Oct 23, 2009 • Freezers
1helpful
2answers
I don't know how to shut my freezer off to defrost it
you can turn the temperature dial to zero or you can unplug it. dont worry about warming up beverages but perishable from your fridge into a cooler
Aug 22, 2009 • Freezers
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
2answers
Top Beverage-Air Freezers Experts
Marvin
Marvin
Gil Shultz
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
