Advent Netbook Logo
A
Anonymous Posted on Jun 15, 2014
How do i print screen on an advent laptop - Advent Netbook
Martin Grant
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 16, 2014
Martin Grant
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
47
Points
Right click,scroll down to PRINT
How do i print from advent windows 8 lapto
Have you added the printer to the Laptop? Wired or Wireless? This should get you started: http://www.groovypost.com/howto/setup-printer-windows-8/
1helpful
Advent 7111 narrow screen
If the display isn't going full screen, on that 15.4 inch TFT LCD screen, the problem is the screen Inverter, or LCD screen itself.
90 PERCENT OF THE TIME the fault is the screen Inverter.
It isn't a simple screen resolution setting that needs to be changed.
http://www.laptoppowerjacks.co.uk/advent-inverter/advent-7111-7107-8315-lcd-screen-inverter-as023217127-iv09140t-lf.html
Primer:
An LCD screen does not produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
It needs an additional light source.
The additional light source is a Backlight.
A Backlight can be a CCFL, or a series of LED's.
The Advent 7111 Notebook PC uses One CCFL,
http://www.screencountry.com/index.php?section=products&model=7111&brand=Advent&size=
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick. Length is almost as long, as the LCD screen is in height. 2mm is close to 1/16th of an Inch )
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Primer over.
I don't have access to a Service Manual, for the Advent 7111 Notebook PC. I haven't had one come to my shop for repair.
I DO have years of experience at repairing laptops, and I see the Advent 7111 is just a basic laptop, as I HAVE repaired over the years.
If you wish, I can guide you step by step, in replacing the screen Inverter.
(MANY people go out, and buy an LCD screen, when the problem is a much less expensive screen Inverter. Afterwards they buy the screen Inverter. Too bad they didn't come here first)
Post back in a Comment.
Regards,
joecoolvette
[ The Advent 7111 Notebook PC is just a re-badged Quanta TW3M.
According to the source, you should see TW3M on the bottom of the laptop.
http://www.uktsupport.co.uk/advent/laptop/7111.htm
2answers
Screen on laptop advent 7102 very dull can hard use it hardly any brightness
The LCD screen for the Advent 7102 does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
An Inverter (Screen Inverter) converts electricity from the laptop, for the LCD screen, and the Backlight.
90 PERCENT OF THE TIME the fault is the Inverter.
The Inverter is a small circuit board located behind the Display Bezel, and under the LCD screen.
[ The Display Bezel is the thin plastic frame in front of the LCD screen. Resembles a picture frame ]
Example of a screen Inverter for an Advent 7102 Netbook PC,
http://www.laptoppowerjacks.co.uk/category-27/Acer12.html
Regards,
joecoolvette
Hi, i have a Advent 3001 roma laptop, unfortunatly i dropped it this morning and the battery fell out, after replacing the battery and turning it back on the screen is very dark, i can only barely see the...
sounds like the light bulb inside the LCD screen broke its hair thin and very fragile will have to replace screen could be more expansive than a new laptop.
2answers
FONT SIZE ON MY EMAILS ARE TOO SMALL WHEN THEY ARE PRINTED OUT
When you are already typing the email on the message body, press and hold and then scroll up the wheel of your mouse.
2answers
Advent 7098 faulty screen?
Angle the screen to the light. If you can see a faint screen image then it's probable that the backlight's inverter has either failed, it's cable has become damaged or the backlight has failed. Both of these can be tricky to replace unless you have the right tools, but can be done provided you can get a spare. Usually it's a tech job.
If the image is not there then it's either the screen itself, the graphics chip or, more likely, the ribbon cable that connects the screen to the motherboard.
You can rule out the graphics chip by plugging the laptop into a monitor.
Of course, the ultimate problem is that you've bought an Advent laptop! And most techs agree that Advent produce the worst laptops in the world. :(
Top Advent Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
