Question about Tomtom One XL GPS Receiver
How to reset tom tom 4er41 - Tomtom One XL GPS Receiver
How can I get free map downloads for my TOM tom live 820 gps
I never registered my life time maps perhaps this is the problem
Feb 19, 2015 | GPS
I turn the power on but only the orange screen comes on with tom tom one on the screen. Screen not changing at all
If you turn on your tom tom gps device and the only thing that comes on is the tom tom display screen, then you need to reset it first. To reset it, what you have to do is to hold down the power on/off button for about 15 seconds and that will reset your tom tom, if it does the same, then you have to reinstall the tom tom application on it.
To reinstall its software, you connect it to a computer then it will detect the device, then the latest software downloads will come up, download it on to your gps, now when you plug it into your car and turn it on, it will get passed the tom tom display screen and start up normally.
Hope this information helped.
Dec 23, 2010 | GPS
My tom tom is over 2years. I am not getting a signal. Asks if I am in a building
Mainly the problem with this tom tom one is that it comes up with this problem frequently. The solution to this problem is for you to reset your tom tom by holding the reset button for a while, after doing that, it will reset it and it will be able to receive signals.
Solution: Reset the tom tom by holding down the reset button for a while, it will reset it and then it will be able to receive signals once again. To reset: check that your battery is properly charged, by plugging it for at least two hours, make sure the charging light is on. Then you press and hold the power on/off button for about 15 seconds, then it will restart the system for you.
Be sure to have your tom tom in a car or in a outside position where it can receive signals from the satellite.
This should do the job.
Dec 22, 2010 | Tomtom ONE GPS Receiver
Tom tom one
You simply need to reset it. Download manual, and it shows you where the reset is.
http://download.tomtom.com/open/manuals/one/refman/3_EN_US/TomTomONE_manual.htm
Mar 11, 2010 | Tomtom ONE GPS Receiver
The TMC was working fine on my tom tom ONE XL but has now suddenly stopped recognising it when connected. I connect, turn on the tom tom but no receiver indicated. can you help please?
Try resetting the Tom Tom.
To do this: Stick the end of a paperclip into the reset hole in the bottom of the receiver. See your manual for the details on this.
This fault is often caused by unplugging the receiver from the navigator before turning the navigator off.
Oct 15, 2009 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
Tom tom will not turn on, but charge light works.
Please connect your tom tom to the power adapter first.Get a paper clip and press the reset button under the SD card slot of your tom tom.Reset button is a very small small hole at the back near the sd card slot.Keep pressing the reset button for 2mins and also press the power button till the light comes on.
This should fix the issue.Let me know if you need any more help.
Jul 08, 2009 | GPS
Tom tom will not switch on
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
How do I reset to factory settings how to reset factory settings on tom tom one
Which Model of Tom Tom One ?
XL
3rd Edition
2nd Edition
make sure you're fully charged, remove any optional memory cards (depends on the unit) there should be a reset hole, place a straightened paperclip into the hole and press for 15 seconds.
140/130/125
make sure you're fuly charged, press and hold the on/off button for about 15 seconds until the unit restarts
Mar 18, 2009 | Tomtom ONE GPS Receiver
I have a Tom Tom One T purchased about 7 months ago. It has suddenly stopped receiving Traffic Information. When the RDS -TMC is plugged in my Tom Tom does not detect that it is connected. Can anyone offer...
Use a paperclip in the reset hole in the bottom of the navigator. See the manual for more details on resetting.
Often this problem is caused by unplugging from the antenna while the navigator is still turned on.
Nov 27, 2008 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
MY TOM TOM GO 700NOT CHANGE TO REGULAR MODE
wrong upgrade by the internet call the factory to reset
Sep 09, 2007 | Tomtom GO 700 GPS Receiver
Tomtom One XL GPS Receiver Logo
106 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
