SEIKI Digital SE32HY27 32" LED TV 1280x720, 60 Hz, HDTV Logo
A
Anonymous Posted on Feb 02, 2018
When turn on screen displays picture options and does not respond to remote, but here tv
Everytime we tyrn on tv it does this, display a selection for tv display standard or hd. Tv locks here for 2-4 minutes and sometimes shows picture. Other one we bought ( duplicate model) has no issues setup same as other.. Very disturbing. Remote does not all you to move to select tv type....
greg ferreira
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 97 Answers
  • Posted on Feb 02, 2018
greg ferreira
Expert
Level 2:
New Friend:
Greenhorn:
Answers
97
Questions
0
Helped
26591
Points
305
How do I reverse the picture on my SEIKI SE32HY10 TV
To reverse the picture on your SEIKI SE32HY10 TV, you can try the following steps:
  1. Press the "Menu" button on your TV remote to access the main menu.
  2. Use the arrow buttons on your remote to navigate to the "Picture" or "Display" menu.
  3. Look for an option called "Picture Orientation," "Mirror," or "Flip Horizontal/Vertical."
  4. Use the arrow buttons to select the option and press "Enter" or "OK" on your remote.
  5. Check to see if the picture has been reversed. If not, try selecting a different option if available.
If you are unable to find the "Picture Orientation," "Mirror," or "Flip Horizontal/Vertical" option in the Picture or Display menu, it's possible that your TV may not have this feature. In this case, you may need to contact SEIKI customer support for further assistance.
Change picture size firetv
To change the picture size on Fire TV, follow these steps:
  1. Go to the Settings menu on your Fire TV.
  2. Select "Display & Sounds" or "Display & Sound" (depending on your Fire TV version).
  3. Scroll down to the "Display" section and select "Calibrate Display".
  4. Choose the option that matches the aspect ratio of your TV (e.g. 16:9 for most modern widescreen TVs).
  5. Follow the on-screen instructions to adjust the picture size and position until it fits your screen properly.
  6. Once you're satisfied with the changes, select "Save" to apply the new settings.
Alternatively, you can also adjust the picture size and zoom level directly from the video playback screen. While watching a video, press the "Options" button on your Fire TV remote and select "Picture Size" or "Zoom" to adjust the settings.
Note that the exact steps and menu options may vary depending on your Fire TV version and software version.
TC-L32C5 - after 1 or 2 minutes from turning on..the display is fading and becoming all black display but the sounds stays loud and clear without issue. How can I resolve this problem?Thanks
Lines on the screen (vertical/horizontal lines, bands)
Image diagram of symptom
Press the HOME button on the remote to display the TV menu screen.
When the issue occurs in the Menu screenThere may be an issue with your TV. Follow these steps to troubleshoot:
  1. Restart the TV and check if the issue is resolved.
    1. Turn off the TV and unplug the AC power cord (main lead).
    2. Keep the TV unplugged for 2 minutes.
    3. Plug in the AC power cord (main lead) and turn on the TV to check its status.
  2. If the above steps does not help to resolve the symptom, the product may require service. Go to Product Repair.
When the issue occurs on other than the Menu screen There may be issues with the broadcast signal source, Cable/Satellite box, IPTV, or other devices such as a DVD player.
NOTES:
  • If this issue only happen to one particular channel or broadcaster, this may be due to the broadcast signal source. Please contact your service provider for further information.
  • If you experience issues when connecting a TV and an Audio/Video device via an analogue cable (composite or component cable) or HDMI cable, check the following section of this article before proceeding the steps below: Screen issues (Lines/Blurred/Odd colours) from the Audio/Video device
  1. Turn off any electrical or battery-operated devices that may be creating radio frequency (RF) interference.
  2. If using an antenna, broadcast signals are reflected by nearby mountain or surrounding tall buildings and may cause ghosting in the picture.
    It is recommended to adjust the antenna direction and location.
  3. Try plugging the power cord into a different electrical outlet and/or surge protector.
    These symptoms can occur if the electrical outlet is improperly wired or not producing the proper voltage.
    If using a surge protector or extension cord, it also could be faulty.
(Back to top)
How to perform a software update.
  • Clean the TV screen. Refer to the following FAQ.
    How to care the LCD TV
  • If the above steps do not help to resolve the symptom, the product may require service. Go to Product Repair.
  • When the issue occurs on other than the Menu screen There may be issues with the TV settings, broadcast signal source, Cable/Satellite box, IPTV, or other devices such as a DVD player.
    NOTE: If you experience issues when connecting a TV and an Audio/Video device via an analogue cable (composite or component cable) or HDMI cable, check the following section of this article before proceeding the steps below: Screen issues (Lines/Blurred/Odd colours) from the Audio/Video device
    1. For TVs with the Motionflow function, select Standard or Off.
    3. The quality obtained from DVD discs recorded on home DVD recorders often varies due to different quality settings being used on the recorders.
      Picture quality from VHS tapes often appears to be significantly worse than other sources, symptoms often include grainy and watery picture.
    4. Reset your TV to the factory defaults. Refer to the instruction manual supplied with the product. Manuals are posted on your model support page.
    (Back to top)
    Picture and video on the TV is displayed doubly.
    (Back to top)
    The screen appears to have a cloudy, white shadow or bright spots when there is no input or when viewing very dark scenes.
    (Back to top)
    Adjusting the Picture setting on my Android TV
  • For other than Android TVs: Adjusting the Picture setting on my LCD TV
  • (Back to top)
    How to reset an Android TV?
    How to perform a power reset on a Sony television.
  • Update the software of your TV to the latest version.
  • (Back to top)
  • If your TV has a reset function for its picture settings, follow the instructions below to reset the settings.
  • Press the HOME or MENU button on the remote control.
  • The next steps will depend on your TV menu options:
    • Select Settings- Display & Sound, Picture & Display or Display - Picture or Picture adjustments - Advanced settings - Reset.
    • Select Settings- Display - Picture - Reset.
    • Select Settings - System Settings -Picture - Reset.
      NOTE: If your remote control has the Option button, you can reset the settings by pressing the Option button on the remote control - Picture or Picture Mode - Reset.
  • Restart the TV and check if the issue is resolved.
  • If the TV is connected to an active and stable Internet connection, install the latest TV software. Refer to the following FAQ.
      1. Press the HOME or MENU button on the remote control.
      2. The next steps will depend on your TV menu options:
        • Select Settings - Display - Picture - Reset.
        • Select Settings- System Settings - Picture - Reset.
    • Check if the cable is firmly connected to the TV and the connected device and make sure it is not loose.
    • Use a spare cable to replace the currently used one and see if the situation will improve.
    • Use another input terminal of the TV.
      1. Connect your device to other input terminals of your TV.
      2. On the TV's supplied remote control, press the input button to switch to the input method that corresponds to the connected device and check if the situation improves.
    • Connect another A/V device to your TV using the same input terminal to check whether the connected A/V device causes the issue.
    • If using an antenna, broadcast signals are reflected by nearby mountain or surrounding tall buildings and may cause ghosting in the picture.
    • Turn off any electrical or battery-operated devices that may be creating radio frequency (RF) interference.
    • Reset your TV to the factory defaults:
    How to reset lamp w/o remote panasonic pt-52lcx16
    Instructions
      • 1 Pressicon1.png the "Power" button on the TV remote control to turn the Panasonic rear-projector TV on and display a picture on the screen.
      • 2 Press the "Menu" button. The "Main Menu" will appear on the screen. Press the "Option" button.
      • 3 Press the "Enter" button. The "Optional Menu" screen will appear. Press the button to select "Lamp Runtime."
      • 4 Press the "Enter" button and hold it for about three seconds. The "Lamp Runtime" will change to display "Time Reset (Powericon1.png Off)."
      • 5 Press the "Power" button to turn the TV to the off position.
      • 6 Unplug the power cord from the electrical socket. Wait about one minute and plug the TV into the electrical socket
    Read more: http://www.ehow.com/how_7201809_reset-lamp-timer-panasonic.html#ixzz33LeXpAsl
    LG 42LC7D turns on ok but no display or sound,tried using monitor out with another tv but no picture either
    Check to make sure you have the right input selected for the input that ou have plugged into.
    How to adjust color for better picture
    Hello there,
    For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
    Adjusting Your HDTV Settings
    Using the On-screen Display (OSD)
    The remote control or the control buttons on the side of the TV can control all the function settings. The
    OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
    settings, even if the TV is turned off.
    The OSD consists of several menu options. The main menu options may vary depending on your
    selected input source.
    Note: Some of the main menu options may have additional submenus, for example, the TV Rating
    submenu for Parental Controls.
    The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
    Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
    to the settings, even if the TV is turned off.
    The HDTV Settings App consists of several menu options. The main menu options may vary depending
    on your selected input source.
    1. Press the VIA button.
    2. Press ? or ? on the remote control to select the HDTV
    Settings App, and then press OK. The Main Menu will be
    shown on the screen.
    3. Press ?, ?, ?, or ? on the remote control to select one of
    the menu options:
    ? Input
    ? Wide
    ? CC
    ? Sleep Timer
    ? TV Settings
    ? PIP
    ? Network
    ? Bluetooth
    ? Help
    4. Press OK to select the option or feature you want to adjust.
    5. Once the menu option is displayed, press ? or ? on the
    remote control to select one of the items to adjust.
    6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
    7. Press BACK once to return to the previous screen. To return to your program once adjustments
    have been completed, you can do one of the following:
    a. Press EXIT on the remote control.
    b. Press the RED button on the remote control.
    c. Highlight and select the RED X in any menu.
    i hope this was helpful don't forget to Rate
    Remote control not working with tv
    The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
    The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
    1helpful
    Have to turn off the pvr then on again every time the tv is turned on due to ''no signal'' being displayed though aerial works fine. The pvr does a scan each time and gives the option of a full channel...
    I think the problem lies with what input you have selected on your tv. On your (tv) remote control there should be either a circle or square with an arrow on through it. With your pvr already switched on, turn your tv off then on again. When it says no signal, press the button on your tv remote I've described until you see a picture.
    23helpful
    3answers
    Samsung LE32R74BDX 32 in......
    just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
    Top SEIKI Digital Televison & Video Experts
    ELECTRICKSUSA
    ELECTRICKSUSA
     Mikey
    Mikey
    Are you a SEIKI Digital Televison and Video Expert? Answer questions, earn points and help others
