Check the settings of the monitor for audio volume. Also check the individual volume control setting for the applications and system sounds. Or call ViewSonic technical support for assistance.
Go into function and look for the volume setting for your main voice - could be R1. This will give a numeric value of 127 or less. It sounds like you need to increase it, try 100 as that is usually sufficient.
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
Goto Control Panel
Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
In device Volume Click Advance
Master Volume Control Window will open
Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Some models have a volume limit setting, check the MENU and look at the audio settings.
If this has external speakers use other speakers. If it has audio output connect them to a external amp and useing the remote adjust the volume. Check if audio settings are set to internal, external and fixed or vairable output.
Often it is to do with the kind of sound that is being outputted by the DVD player. If the sound for example is set to produce dolby 5.1 and you don't have a suitable decoder it will be very low.
Check the sound settings of both your DVD player and sound system.
