Question about Hotpoint Refrigerators
The fridge model no ishts17gbserww the drain line coming down from freezer must be clogged because the water drips down in the fridge compartment i did not take off the back plate off yet in freezer but i will and hope the freeze line is behind the wall plate is it there? also it is there what solution will free it up?
jmartin50
  • 29 Answers
After removing back plate you will see a drain line that comes down and has a rubber duckbill device on the end of it. This is to prevent warm air from entering the freezer but also allow water fro the auto defrosting cycle to drain out. This duckbill device gets sticky with time and will seal shut preventing the defrosted ice water from draining into the pan to evaporate away. You can take this duckbill off and clean it but I have always just replaced them. It may look different on yours.
https://youtu.be/_MyOFwRWRTY
Posted on Oct 22, 2017
5 Related Answers
David Coomer
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
Anonymous
SOURCE: freezer dripping water down to fridge, drain hole freezing up
check your tubing for auto ice maker if you have one. It my be clogged. This happened to us with a $100.00 repair for tec to blow through it to fix.
Posted on Sep 10, 2009
Anonymous
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
Anonymous
  • 619 Answers
SOURCE: Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Posted on Feb 04, 2010
geoff hunter
  • 4793 Answers
SOURCE: Water in bottom of the fridge. I figured the
copper wire is best with a bit of cloth to pull thru
Posted on Feb 06, 2010
Water dripping in fridge from below frezer
There is a drain tube that runs from the freezer/ evaporator compartment that allows ice melt water to drain from the defrosting cycle. Often times that drain hole will become clogged with food debris, glass from a broken heating element, paint chips from scaling and mildew, etc. When that drain hole gets clogged the water has no place to go except down into the fresh food compartment. Unplug the ref and remove the food and ice maker and racks. Remove the freezer back panel and look for a drain hole and clean it out. I use a wet/ dry vacuum at first and if the clog is deeper I will use compressed air to blow the line clear. You can also use a water hose with water pressure. Best done outside of the house.
Feb 09, 2014 | Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
Water dripping from freezer into refrigerator
Hi,Most likely the drain in the freezer is clogged up and frozen. Every time when your fridge automatically defrosting defrosted water dripping inside the fresh food compartment. You have to remove the back panel in the freezer and using a hair dryer defrost the drain which is located under the evaporator coil. Then put very hot water through the drain until it goes free.
Yes, you need to remove the back panel inside the freezer, It should have screws that come out then it should pull off and out.
On your model, the defrost drain hole/line is located inside of the freezer behind that back access panel, just remove that back panel, remove your freezer floor panel FIRST(Has 2 screws in front), that simply pulls out, then you will see the drain hole under the evaporator coil. It may be iced up, you will have to clear all of the ice and run hot water down the drain hole.
Once the back panel screws are removed that panel should just pull off, pull hard. Make sure your refrigerator is unplugged first.
Good luck.
May 28, 2011 | Kenmore Top Freezer Refrigerator
When the refrigerator defrosts, the water does not make it down to the pan to evaporate, water is dripping down on top shelf and under crisper draweres...how can I find the area to find a clogged up line?
The drain line is located in the freezer compartment. Remove the contents of the freezer and take the back panel off. Once the panel is off, you should see the evaporator coils. The drain is located below the coils in the center. Remove any dirt and debris around the drain opening. Use a lenght of wire and insert it down the drain tube to clear it from any blockages. Pour some warm water down the drain opening and check it flows into the drip pan below the fridge. Hope this helps you.
Mar 09, 2011 | Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Feb 04, 2010 | Refrigerators
Refrigerator is dripping water inside, from the vents between the top freezer and into the bottom fridge. Model # ER2HCMXPL00. What is the fix?
Every 8 hours or so it defrosts and melts the ice on the freezer coil. There is a drain hole in the back of the freezer compartment that tends to get clogged.  Take all of the stuff out of your freezer.  Take the back panel off, get a hair dryer and melt all of the ice.  It will take a while.  Find where the water drains and plunge the hole with a coat hanger.  Once in a while the drain line gets clogged at the bottom where it comes out to so check down by the compressor for cloggs too.
Dec 04, 2009 | Washing Machines
Freezer leaking into refrig compartment how do i
need to know the brand or call me at 813-270-4029
Aug 22, 2009 | Refrigerators
Kenmore # 63142 Fridge -- Water in Freezer
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
Apr 04, 2009 | Kenmore 63142 / 63144 Top Freezer...
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
peter gittos
peter gittos
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
