Question about Brother MFC-9840CDW Laser Printer
How to print test page on a Brother MFC-9340CDW?
Laurie B.
    New Friend:
  • 4 Answers
Menu, 4, 2, 3, start
Posted on Jun 17, 2014
5 Related Answers
Mergatroid
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
Anonymous
SOURCE: I replaced all the ink and my brother mfc 240
i replaced all the ink and my brother mfc 260 still wont print black, or copy black, or test print black
Posted on Mar 27, 2009
ryeisenman
Richard Eisenman
  • 9 Answers
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Posted on Nov 21, 2009
ctnozil
  • 270 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
Anonymous
SOURCE: Brother MFC 5860cn magenta color is not printing
This can happen if the ink dries out for a long time. Try to power flush the color that doesn't work.
Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
press 7 then 6 then 4 then start black copy. This will fill the tubes with ink.
press 7 then 6 then 3 then start black copy. You may use the right arrow to choose the color you want to flush before you press the black copy button.
Press 99 to exit maintenance mode
Press the ink button and do a test print for print quality and see if the color you flushed works. If not, try again.
This is the only way to fix the dried print head. Otherwise you have to replace the print head, in which case, you might as well buy a new printer.
Posted on Dec 10, 2010
Brother MFC not printing in color
go into printer properties and set the colour as default.
normally when you go to print something there is a tab section that will get you there before you actually press print
May 24, 2015 | Brother Wireless Color Laser MFC-9340CDW...
Default passwords
If you contact the manufacturer, they should be able to provide this needed default password. Best Wishes
Sep 01, 2014 | Brother Wireless Color Laser MFC-9340CDW...
Brother mfc-9340cdw does not print nothing in spool
Sir/Madam
Please Go To Official Hp Printer Website To resolve You Hp Printer Issue Below Link URL:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02205477&cc=us&dlc=en&lc=en&product=5199463#N93
Or
If You still having Problem Then Follow Us On for HP Printer Online Assistant On:
HP Printer Support
Feb 10, 2014 | HP PHOTOSMART 7520 E-ALL-IN-ONE
Mfc465cn-cant print test page,error PRINTER BUSY
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: How do print network configuration page Brother In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Jan 22, 2014 | Brother Any 8 Inks Mfc-465cn Mfc465cn...
Im only getting balck and yellow i have a mfc 5890cn printer
Try to print a test page, if this comes out in black in yellow take out the cartridges and make sure the plastic is taken off the bottom and pop them back in. Do a test page again. Does it now print in colour and are there any errors on the machine or pc? i.e. out of ink?
Aug 17, 2011 | Brother MFC-5890cn Color Flatbed...
How can I set my MFC-240C printer to print from my computer
switch on the printer
1. install driver for mfc-240c
2. go to control panel in your computer
step to control panel
select START then control panel
3. select printer mfc-240c right click on it and then click on click on <Set as Default Printer>
4. right click again on it the select <properties> then select "print test page"
test page will printout on printer
5. now you can use mfc-240c as printer
Aug 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-215C prints only top of page
try to re install the printer driver..
thank you ...
Jul 17, 2009 | Office Equipment & Supplies
No print at brother mfc-24c
"Machine Error 50" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
However, if that doesn't work, the error is mechanical, and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a brother mfc 3240C. I have changed the
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Apr 23, 2009 | Brother Office Equipment & Supplies
My brother mfc 3420c want print
hmmm..well...does it do a test page, without being connected to computer? do you have users manual?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Brother MFC 3420C All-In-One InkJet...
Brother MFC-9840CDW Laser Printer Logo
730 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
