SOURCE: Need User Manual
Go to Jacuzzi.com and plug in model and serial no. you should be able to find an operation manual there.
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
SOURCE: my jacuzzi baths pump makes a noise when i turn it
you have a bad pump. has a bad spot on the motor, that is why it doesn't start. What model number of pump?
SOURCE: whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
SOURCE: jacuzzi whirlpool bath not working when i turn it
buzzing sounds tend to be a motor problem. You may need to change the pump. When you turn it on it just buzzes? that indicates a bad motor.
