SOURCE: 2000 ford focus twin cam timing
please helpme i need timing marks for ford focus 2000 16 valvs
SOURCE: head bolt torque specs and timing marcs for a 94 volvo 960 6cyl
you do 14 foot pounds then 45 foot pounds then a 120 degree turn.if aluminum heads are what you have
SOURCE: Correct way to align timing marks
hi -- the timing marks on a twin cam are tricky!! heres how- turn the motor over to tdc on the bottom pulley,this will align two marks on the lower cog-----now on the top cog,it has an obvious mark near the teeth-- well disregard this for now!! the cog has a hole in it,in one of the spokes,well this goes at 12 o,clock and lines up with a mark you will see on the housing! now if you are right you will see the mark near the teeth is at around 4,oclock---i just did one and it is right--cheers
SOURCE: vw golf 1.4 16v after changeing timing belt car
The timing could be 180 degrees out you will have to do it all over again. Bring #1 cylinder upto TDC check the distributor rotor arm that it is pointing to #1 plug wire, It is important that the cams are on the intake stroke and not on the exhaust stroke. The crank is no big deal just make sure the marks are lined up.
SOURCE: timing marks on twin overhead cams 2.4 and crank mark.
Click on the following direct, Free Link. It has several Diagrams including the Timing Belt + Marks for your 2004 Hyundai Sonata 2.4L DOHC In-Line 4-Cylinder Engine (located on the bottom half of the Page on the Link). There are additional Diagrams that will prove to be helpful while you are doing this...
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2004/make/hyundai/model/sonata/2004_hyundai_sonata_timing_belt_diagram_marks.htm
Testimonial: "tHANKS, tHIS WILL DO THE JOB."
