Question about Zanussi FJS1225W Front Load Washer
Problem with Zanussi washer/drier ZWD162701 1600 rpm: washes fine, but error msg E20 appears when drying cycle starts. Cleaning fluff trap does not help. Any help greatly appreciated. Steve.
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
Posted on Jul 18, 2007
Anonymous
  • 1294 Answers
SOURCE: Zanussi ZWD1471W Washer Dryer error codes help please!
Click on Zanussi (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 05, 2007
robotek
Graeme Ross
  • 1512 Answers
SOURCE: WASHING MACHINE FRONT LOADER
HI there, doing some research for you now....
Posted on Mar 10, 2008
Anonymous
  • 56 Answers
SOURCE: Error E20 showing ........stops during wash cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Posted on May 12, 2009
Anonymous
  • 53 Answers
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Posted on Nov 01, 2009
Testimonial: "Thank you so much - exactly right"
ZANUSSI JETSTREAM, CODE E20 appears with every wash near the end of cycle
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out
If still the problem persists then the problem is with the draining pump.Replace it and this wont come again
Thank You
Sep 09, 2010 | Zanussi Washing Machines
Error E20
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Why can i not get the dryer to work? error E20 is flashing.
HI,
Can you hear the pump trying to drain it when you start a cycle? If not it needs a new pump.
Is there a block in the drainage pipe (blow down it and see if it bubbles in the filter compartment). Or a block in the drain - try pouring some water down in.
Otherwise, I had the same problem (an E20 but a clean filter, no blockage and working pump) and it turned out the condenser (a large plastic vessel) or the right side of the machie (you have to take the whole back off) was full of fluff. The engineer just used a wire hanger and ran it under water to clean it out.
If you've found that it hasn't been drying the clothes fully recently that could well be the problem.
Sep 24, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Washer front loader
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Problem
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washer/dryer zwd1471s
E20 normally means there is a blockage in the drain tube/filter. I have the same problem, but the drain tube is clear. I have searched the web and found the solution being down to the "plastic bottle-like condensor having debris/fluff in it".
Nov 30, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
sheakhly
Level 1 Expert
Michael Thomas
Michael Thomas
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
