Baby Gear Logo
A
Anonymous Posted on Jun 15, 2014
DO GRACO SNUGRIDE INFANT CAR SEAT BASES WORK WITH A DIFFERENT MODEL?
Marc Cohen CPSTI
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 158 Answers
  • Posted on Aug 16, 2014
Marc Cohen CPSTI
Expert
Level 2:
New Friend:
Cheetah:
Answers
158
Questions
0
Helped
25868
Points
177
Some do, some don't.
From Graco's web site:
What base will work with my car seat?
We have designed many of our car seats to work with more than one base, for your convenience. Please see the chart here for Classic Connect models.
The SnugRide Click Connect 30, 35, 35LX and 40 infant car seat carriers are compatible with any SnugRide Click Connect infant car seat base. Consumers should adhere to the height and weight requirements for the SnugRide Click Connect infant car seat carriers as stated in their owner's manual; however, the SnugRide Click Connect 40 infant car seat carrier is restricted to a height limit of 32 inches when used with a SnugRide Click Connect 30, 35 or 35LX base.
1 Related Answer
Anonymous
  • 125 Answers
  • Posted on Aug 19, 2008
SOURCE: Graco Snugride Infant Car Seat
HI! I've had 3 babies and alwyas use the Sungride! My presonal trick......First, be sure to roll up a towel (try different sizes for the perfect fit) and push it under by the seat crease (where the back cushion and seat cushion meet). Then, when you are pulling the belt to make it tighter, put your knee in it to add some weight and really get it tightened! I'm sure you'll notice a world of difference! :)
ANy adjustments to be made to make a 4 month baby sit in Graco trilogic car seat ?
The Graco Quattro Tour travel system is one of the most popular styles, thanks to the big basket, one-hand fold and nice parent tray. There are some downsides to this travel system, though. Most notably, the Quattro Tour stroller is big, whether folded or unfolded, and it's heavy to boot. Whether you choose the regular version or the Graco Quattro Tour Deluxe travel system, the included infant car seat will be a winner. Paying extra for the Deluxe buys you a higher weight range on the car seat, which means a longer useful time, but again, adds weight to the whole system.
Graco Quattro Tour Travel System FeaturesThe foundation of the Graco Quattro Tour travel system is the Quattro Tour stroller, a full-size model with an aluminum frame. It also has one-hand folding, a multi-position reclining seat (including fully reclined for infants), a drop-down basket that can be accessed even while the seat is reclined, and a sunshade that rotates to cover nearly any angle you need. The parent tray has two cupholders. The front tray also has a cupholder for baby, and it swings open for easier access with bigger toddlers. The regular version of the Graco Quattro Tour travel system comes with a Graco SnugRide infant car seat, which holds babies up to 22 lbs. and less than 29 inches. The Quattro Tour Deluxe travel system comes with a SnugRide 32, which holds babies up to 32 lbs. and 32 inches. The difference in car seats is the only real difference between the regular and deluxe versions of this travel system.
What I Like About the Graco Quattro Tour Travel SystemOf the infant car seats that come with travel systems today, both the Graco SnugRide and the SnugRide 32 are good choices. These car seats are fairly easy to use, and they install pretty easily in most vehicles. Some of Graco's less expensive travel systems include a SnugRide with a back-adjust harness, but the car seats included with the Quattro Tour travel systems are a front-adjust version, which is much easier to use properly. You can use both SnugRide seats without their bases, as well, which is a plus. The Quattro Tour stroller feels sturdy out of the box and has a respectable 50 lb. weight limit. The steering is OK for a stroller of its size and price - better than average for full-size travel system strollers.
The one-hand fold on the Quattro Tour stroller works well. You just have to twist the middle of the handle and let gravity help the stroller fold itself. Since you have to deliberately twist the handle, though, there's not much chance of the stroller collapsing accidentally as there would be if you just needed to push a button or lever.
The basket on the Quattro Tour stroller is big enough to fit a large purse or diaper bag. It also has a nifty drop-down feature so you can get into the basket even if the stroller seat is fully reclined (a common problem on full-size strollers).
The canopy is good-sized and rotates around to cover almost any position needed. It's easy to put the seat into the fully upright position, and I like that it reclines all the way, in case you don't want to use the infant car seat in the stroller all the time.
What I Don't Like About The Graco Quattro Tour Travel SystemThe Quattro Tour stroller is heavy. At more than 26 lbs., you may get pretty tired, literally, of lifting this stroller in and out of your trunk after a few weeks. It's not small in terms of dimensions, either. When the stroller is open, it's just over 24 inches wide, which doesn't leave a lot of clearance for narrower doorways. Some parents complain that the wheels, which stick out a bit from the frame, are easily caught on things in stores or in other tight spaces. When the Quattro Tour stroller is folded, it's smaller, but not by a lot. It measures nearly a foot and a half thick and about two feet by three feet, which means it will pretty well fill the trunk of the smallest cars. Though the steering is better than most full-size, lower-priced travel system strollers, it's still not great. Once you've added a heavy toddler (or a bigger infant plus the infant car seat and a diaper bag), the steering can be a bit balky.
While the folding mechanism is sleek, unfolding the stroller is awkward. Similarly, while the seat is easy to move up, it's harder to recline.
The biggest problem with the Graco Quattro Tour stroller is durability. While this model seems to have a better track record than many of Graco's travel system strollers, there are still plenty of parents who complain that their Quattro Tour stroller is creaking and wobbly after a year or so of constant use. This is probably not a stroller that will last through multiple children, and you likely will not recoup much money by reselling it later on.
Should You Buy A Graco Quattro Tour Travel System?The Graco Quattro Tour travel system is not a bad choice if you're set on a travel system already. Many of its downsides won't be answered by choosing another brand or even another of Graco's travel systems. If you have realistic expectations about a travel system in general, you may be very happy with the Graco Quattro Tour. The infant car seat is the most important part of the travel system, and you can't go wrong with the front-adjust SnugRide or the SnugRide 32. You should try out the car seat in your vehicle before you buy the travel system, if at all possible, just to be sure it's a good fit. If the car seat doesn't fit your vehicle, that would be one reason to choose a different travel system.
In the whole of the stroller world, the Quattro Tour stroller wouldn't be one of my first choices since it's heavy, bulky whether folded or unfolded, and doesn't have a great track record for durability. However, as far as travel system strollers go, those things are to be expected. The Quattro Tour stroller is above average on a few convenience features, though, so combined with the decent car seat, it's among the better ready-made travel systems available.
Need replacement level indicator for graco giselle infant seat
go to www.gracobaby.com and type in your model number and serial number (or date of manufactor, and it will bring up all the available replacement parts for your seat.
Cannot tighten graco snugride in my toyota sequoia
Does your Pilot or Sequoia have leather seats? It seems its harder to get them to tighten right on leather. If it is leather, trying getting a seat saver from BabysRUs. They will give you more friction when tighting. Also tr!physically kneeling on the base when installing. I know it sounds crazy but if you shift your weight from side to side its much easier to tighten down. Good Luck|!
Uninstall snugride base
The straps should have a release buckle, just pull it really hard while the carseat is removed. Its a lot easier if you put all your weight on the base like kneeling down on it while pushing the release buckle toward the crease of the seat and alternating weight on the base. Good Luck, and remember, you can always cut and replace the belt if necessary!!:)
How to install a graco carseat.
I just bought a used graco snug ride infant car seat model #7304ge12, and I dont have the manul on how to properly secure the base in my car. I have a Ford Expedition.
Top Graco Baby Gear Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jay Finke
Jay Finke
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
