Onkyo TX-SR605 Receiver Logo
Question about Onkyo TX-SR605 Receiver
Onkyo remote volume not working
Onkyo USA
  • Official Brand Answer
  • 333 Answers
Please contact our Parts & Services Dept at the number listed below during normal business hours Monday-Friday 9am-5pm EST ; or via email at [email protected]. They can be contacted at 201-785-2600, option # 4 for Parts & Services as they can further assist you regarding Onkyo Parts and Accessories. You will need to speak with the Parts & Services department for any parts ordering/ shipping status, and availability or specifications for Onkyo parts and accessories.
Posted on Apr 17, 2015
1 Related Answer
Anonymous
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
Volume knob not working on my onkyo tx-ds656 lost remote everything else works fine...
"Volume knob not working on my onkyo tx-ds656"
replace the volume knob but check the volume control IC first such as voltage and whether an analog signals come out by an oscilloscope.
and " lost remote " Check if the onkyo remote is working, by:
(1)point a mobile or a smart phone camera at an onkyo remote control.
(2)Don't take any photo.
(3)Now the remote picture is on the mobile or smart screen.
(4)Press any remote control key.
(5)White flashing light can be seen if remote is ok.
(6)If remote is fine, replace the remote senor on tx-ds656 with same part number.
Onkyo tx-sr575 remote does not operate volume, have to increase decrease manually, how can i program remote to solve problem
“remote does not operate volume, have to increase decrease manually,” (1)Open remote cover.(2)Clean remote PCB and volume buttons with dry cloth.
(3)add some sliver paint on black colour volume buttons.
(4)wait for paint to dry
(5)remote can be used again.
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
I have an onkyo rc-742m remote and the volume button just stopped working, how can I fix it?
If someone can't increase volume and decrease it from remote (I assume batteries and technically the remote is ok and everything else works on it), just mute and unmute and now Onkyo will let you increase and decrease volume from the remote.
Onkyo Codes for Samsung remotes?
Hi, unfortunately this remote does not have the ability to program to your Onkyo receiver. You must use your original Onkyo remote to control the volume of it. If you need a new Onkyo remote you can purchase one from Replacement Remotes. You can also buy a universal remote to program and work for both your units, so you will not have to keep switching back in forth between remotes. If you would like a universal I suggest getting the RFS200, this remote will even work if your receiver is not in direct line of site.
My Onkyo TX-SR806 remote has recently lost its mind. The On/Standby switch no longer turns receiver on or off; must do it manually on the receiver. The Volume control is now reversed: when you press the UP...
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
2answers
Don't know how to adjust volume on remote speakers
Can I ask you something? I have the same but the remote doesn't work, and I have no sound in the B speakers. I wonder if there's something that I have to do with the remote, or there's a problem with the receiver, Thanks.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
