Question about Yamaha Electrical Supplies
Need ignition switch and wiring diagram for XG-SF3600 Digital Inverter Generator
1 Related Answer
SOURCE: Digital Inverter Generator XG-SF3600 running but
i have the same problem. I have AC from the windings but nothing leaving the inverter module..Its a sealed unit. There is virtually no parts back up service & if you can track down parts, they are quoting from $ 400 to $ 700 for replacement..If you expect this gen set to last like a honda or yamaha your mistaken..Dont buy chinese unless your short of folding stuff or you only use your gen set occasionally & for those that have had no trouble with theirs, its only a matter of time. trust me, they are a disposable item..
Posted on Nov 16, 2012
Repair manuelpages on ign wires from switch out need wire locations google was no help
Is this a generator of some kind?
Sorry, I don't have a wiring diagram. With a dc starter motor and battery, I don't see why you can't get it to crank, bypassing the ignition switch or button. I don't know what all the ignition switch controls? I realize I didn't answer your question. Just trying to help. Can you contact the manufacturer, see if they can give you wiring info?
Mar 20, 2017 | Cars & Trucks
EU3000is inverter generator. Why won't it start?
Check the switch on /off is not faulty try taking the wire off the switch that goes to the motor mine had that problem (lot of dodgy switches fitted to them ,make sure the choke is closing on fully.check spark plug not fouled up with carbon.
Oct 03, 2015 | Electrical Supplies
2006 honda cbf 250 wiring diagram needed... or need to know what wires are what out of the cdi/ecu, I have tried everything and cannot find anything... engine has been put into gokart and need to rewire...
from ignition switch red wire supplies power from the battery to the ignition switch, black wires are live when the switch is on but have nothing to do with the cdi The cdi is supplied by the generator on your engine.Green wires from switch are all earthing wires.The black and white wire coming from the switch is the wire that puts the cdi to earth to disable the ignition in the off position .
Dec 17, 2014 | Motorcycles
Where is low oil sensor aan a digital inverter generator
Look on the engine block . There should be a wire on it to the engine ignition magneto.If the engine runs the low oil sensor is not the problem. If the oil is full and the engine has no spark try disconnecting the wire from the low oil switch if you get spark the low oil switch is bad.replace stitch and reattach wire and fill oil to proper level
Dec 01, 2014 | Electrical Supplies
Gentrax 4.4 kva generator looses spark above idle. goes anyone have a wiring diagram???
Itr sounds like a failing ignition module, or incorrect trigger gap
Oct 22, 2013 | Electrical Supplies
Digital Inverter Generator XG-SF3600 running but no current
Sep 06, 2010 | Electrical Supplies
Electrical Supplies Logo
247 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
