Question about Samsung PN50A450 50 in. Plasma HDTV
Why does my tv only come on for a second? - Samsung PN50A450 50 in. Plasma HDTV
LED tv has no picture and flashes on every few seconds
You have a bad panel (TV SCREEN). The LEDs are not coming on. You will have to replace all LEDS, and this can be very time consuming. The LEDs can be tough to find and buy. Many TV parts store are out of stock. Thanks for asking, Matt of Martins TV.
Jun 10, 2018 | LG Televison & Video
My klv-21sg2 sony LCD color tv red light blinks 1 second and off for 2 seconds
OCP ( Over Current Protection ) . Your TV need a thorough checkup. Contact any experienced service technician.
Sep 04, 2012 | Sony WEGA KLV-21SG2 21 in. HDTV-Ready LCD...
Hi, how do i sync my venom dvd remote to my xbox 360? thank you
To enter a TV code:
1 Turn on your TV and point the remote toward it.
2 Press and hold the TV and OK buttons simultaneously for two seconds. All of the buttons on the media remote will then light up for two seconds, after which only the numeric TV buttons (1-12) will remain lit.
3 Enter the code for your TV.
4 Press the TV button again to save the code and exit. All of the buttons on the media remote will blink three times to confirm your selection.
To scan for a TV code:
on the media remote will then light for two seconds, after which only the numeric TV buttons (1-12) will remain lit.
3 Press the CH+ or CH- button to send a series of off commands to your TV. Repeat until the TV turns off.
Jul 02, 2011 | Venom DVD Remote Control for Xbox 360
I need the code to program the remote to an emmerson ewf2006 tv codes
Hello
You haven't specified whether it is a TV/DVD combo or TV/VCR combo.
Four digit universal remote codes for Emerson TV/VCR combo are:
0227 0233 0254 0264
0265 0266 0310 0325 [0039 0252]
[0147 0250] [0147 0257]
For TV/DVD combo is: 0456
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR
For Combo Devices, in many cases a single code operates both parts of the device (e.g. the TV and the VCR). In other cases you need to set up two codes. For example, one for the TV and one for the VCR. Where codes are shown below as [### ###] the first code operates the first part of the device's name, and the second code operates the second part. E.G., for a TV/VCR device, the first code operates the TV and the second code operates the VCR
Jun 19, 2011 | Emerson Televison & Video
Code number to program my bell remote to this tv
01768,11034,11265, 10178, and 11748.
Or you can:
1. Press "TV" button
2. Hold "P" (program button) till the "TV" button flashes once then twice
3. Enter 9 9 1, and the "TV" should flash twice
4. Aim the remote at the TV and hold the Power button down for at least 3 seconds. (Remote automatically goes to first code but it probably wont work so go on to step 5)
5. Press CH+ repeatedly till the TV shuts off and stop immediately!
6. Hold "P" for 2 seconds
7. Hold "Select" for 2 seconds
8. Hold "P" for 2 seconds
9. Hold Power for 2 seconds and TV should turn back on
Found at:http://wiki.answers.com/Q/What_is_the_universal_remote_code_for_a_haier_tv
Be sure to rate macapplezoo 100% or whatever you think I deserve!
May 29, 2011 | Haier HL32D1 32 in. TV
Phillips TV with no on screen menu, only Caption, Text and Sleep. bought TV's from factory auction. PA5032-C102. or 32R505-00BB.
The OSD (on screen menu) is locked. Those two serials (not models) are for two completely different tv's: the first is for an very old standard 32 inch CRT and the second for an old plasma.
To unlock it in the first tv you need to just press the menu button for 10 seconds. For the second tv you must start the tv and immediately press both the menu and channel up buttons for 5 seconds.
Dec 15, 2010 | Philips Televison & Video
How do i get my tv off of fpa lock
Hello
Your TV has locked I thinks. Do the folloing and see if it works. This process can unlocka your RCA tv. You have to reset it V-chio after unlock.
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model the processs mentioned above may differ. You have to go all these, till your TV gets unlocked.
OK.
Dec 03, 2010 | RCA 14F512T 14" TV
I need a code for our Samsung TV/VCR using a universal remote RCA RCRN04GR. Would greatly appreciate your help!
Hello
For Combo Devices, in many cases a single code operates both parts of the device (e.g. the TV and the VCR). In other cases you need to set up two codes. For example, one for the TV and one for the VCR. Where codes are shown below as [### ###] the first code operates the first part of the device's name, and the second code operates the second part. E.G., for a TV/VCR device, the first code operates the TV and the second code operates the VCR.
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR.
0358_0942
Nov 22, 2010 | Samsung CXJ1352 13 in. TV/VCR Combo
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
Samsung PN50A450 50 in. Plasma HDTV Logo
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
