Question about Umax Astra Office Equipment & Supplies
How to remove sump plug on astra cdx - Astra Umax Office Equipment & Supplies
I have a 2004 holden astra cdx (TS series), I've had my car mechanically repaired and now my windows don't automatically roll down. Anyone know how to fix this?
Firstly take it back to the mechanics and explain the situation. If they all don't roll down, then probably a fuse or wiring has been dislodged.
Dec 16, 2016 | 2004 Holden Astra
How do I remove the rear bumper of an AH Astra cdx 2 door hatch its the Opel Belgium made version thanks heaps
We are a USA based site, we do not have this make in this country and have very limited info on any of these makes.
Sep 01, 2016 | Opel Astra Cars & Trucks
I want to do any oil and filter change on my 2006 Astra 4 door hatch it is Holden GM model AH CDx it has an ecotec 1.8l unleaded petrol engine
So what is the problem? The new filter for a Z18XE screws directly on to the front of the engine block behind the radiator, and the oil drains out of the drain plug at the base of the sump. The Z18XER only differs in that the filter sits in a round black housing visible from the top right of the engine and is requires a 32mm spanner to remove the cover. The filter is different from that on the Z18XE
Jul 21, 2016 | Opel Cars & Trucks
How are the rear seats on a Holden Astra CDX 2006 model removed in order to access the fuel sending unit?
They'll either clip in or screw in. Usually you push the front down and slide forward it they're screwed you'll see the brackets at the front of the seat
Apr 13, 2016 | Holden Cars & Trucks
I am looking for a sump for a 2000 Astra. What should I be aware of?
the sumps should be identical and the oil level gauge will be for a low oil level sensor . just make sure that there is a position for an dip stick if it is not in the block
Wreckers will be the best place and one from a rear ended wreck should be good
best get a workshop manual for details of how to remove and fit.
May 27, 2015 | Cars & Trucks
How to remove seats from 2003 holden astra cdx
There should be an electrical connector under the seat.
Jul 29, 2014 | Holden Astra Cars & Trucks
Astra oil problem no oil on cashaft z22e
in what way is the oil a problem..?
does it keep saying there is no oil ?
if it is saying this there is three parts you need to check.
1. is the breather for the sump. ( pipe coming from the bottom to the top of the engine.. ( can become clogged with burnt oil )
2. the oil switch on the sump. ( check for water in the plug if is replace the seal)
3. you need to take off the cam cover and clean out the oil drains. ( burnt oil can block the drain holes).
Feb 22, 2014 | Cars & Trucks
Where is opel astra`s oil sensor connected
sump on the side. prone to let water into the sensor plug when the seal gets weak or splits.
Apr 14, 2013 | 1998 Opel Astra 1.8
Top Umax Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
Mike
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
