Ovens Logo
Question about DCS Ovens
How to calibrate DCS gas oven
RGV2-485GDN - DCS Fisher Paykel gas oven on range will not reach high temperature
Based on the information you provided, it sounds like you have already done a thorough job troubleshooting and attempting to resolve the issue with your DCS Fisher Paykel gas oven.
If the oven is not reaching high temperatures even after you have replaced the igniter and dual gas valve, and swapped the circuit board from the working side, there are a few other things you can check:
  1. Check the oven thermostat: The thermostat is responsible for regulating the temperature in the oven. If it is not functioning properly, it may be preventing the oven from reaching high temperatures. You can test the thermostat with a multimeter to see if it is functioning correctly.
  2. Check the oven temperature sensor: The temperature sensor is located inside the oven and sends temperature readings to the control board. If it is not working properly, it can cause the oven to not heat up to the desired temperature. You can test the sensor with a multimeter to see if it is functioning correctly.
  3. Check for obstructions in the gas line: If there is a blockage or obstruction in the gas line, it can prevent the oven from getting enough gas to heat up to high temperatures. Check the gas line for any debris or blockages and clean them out if necessary.
  4. Check the regulator: The regulator is responsible for regulating the pressure of the gas going into the oven. If it is not functioning properly, it can prevent the oven from heating up to high temperatures. You can test the regulator with a gas pressure gauge to see if it is functioning correctly.
If none of these solutions solve the problem, it may be best to contact a qualified technician to further diagnose and repair the issue with your oven. They will have access to a service manual and specialized tools needed to diagnose and repair the oven.
Nov 22, 2022 • DCS Ovens
DCS oven model RGU-3GS-L will not heat up. need advise on what I can check before call a technican?
Hi Lou, sounds like you have a bad igniter. If it's not drawing enough amps it won't open the gas safety valve. Fairly simple to replace if you're confident working with electrical parts,if not I'd definitely call a repair company. Hope that helps.
Dec 26, 2018 • DCS Ovens
1helpful
How to calibrate my DCS ovens
hi there.
this is all i could find.go to this link and see if it helps you.
How to calibrate DCS ovens Google Search
Nov 19, 2017 • DCS Ovens
Were do i get parts for model fsco covection oven??????????
where are you located?
I have a DCS-FSCO commercial convection oven, how can I help?
DCS FSCO- 1N manual guide
Did you ever get a manual? I'm looking for one as well and want to change mine to LP.
1helpful
DCS gas oven and broiler that pulses
This sounds a lot like a defective pressure regulator. If you do not have one externally connected, then the internal regulator is faulty. If internal, it shouldn't be too difficult to DIY. Just make sure the pressure rating is the same as the one that has failed.
Ignition wont stop while oven is working
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
DCS wall oven very dim display for settings
typical for gas filled displays. check other postings for same problem for correction. part cost is $92.
4helpful
2answers
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS [email protected] 1-888-281-5698 new Zealand.
Top DCS Ovens Experts
vince
NOEL
NOEL
Are you a DCS Oven Expert? Answer questions, earn points and help others
