Vtech CS5121 Cordless Phone Logo
A
Anonymous Posted on Jun 14, 2014
Pressed *21 on vtech phone - to activate going straight to voicemail - how do I turn it off?
3 Related Answers
Anonymous
  • 65 Answers
  • Posted on Jan 26, 2008
SOURCE: How do you leaving a voicemail for your answering machine on the Vtech cordless phone?
ARE YOU WANTING TO RECORD A MESSAGE THAT CALLERS WILL HEAR OR ARE YOU WANTING TO LEAVE A MESSAGE FOR SOMEONE YOU CALLED?
Anonymous
  • Posted on Mar 04, 2009
SOURCE: cant get voicemail
call your own phone number, and once it asks for the password type in the last 4 digits of your phone number.
Anonymous
  • Posted on May 05, 2009
SOURCE: vtech 5.8 ghz phone with voicemail
please help me out
Why is my VTech 6.0 CS6124 go straight to voicemail on all incoming calls?
I found an online handbook manual for the VTech 6.) CS124. I noticed on Page 20 that you can set the number of rings on your answering system. Perhaps changing the number for incoming calls to a higher number might help.
Here's the link to the manual. https://cdn-web.vtp-media.com/media/p/document2/products/%7BD1C79A59-7C89-415D-830F-D57B9ACB6F33%7D/CS6124_UM_2.pdf Hope this helps.
How do you check your voicemail on a VTech cordless phone
The cordless phone pictured appears to be a VTech CS6114
and an Answering Machine System is not part of this phone.
** BUT ** an Answering Machine System is not the same
as "VoiceMail" anyway.
VoiceMail is an option offered by some (not all) telephone
service providers, and each of those who do offer the feature
employ specific procedures unique to themselves.
Check with your Telephone Service Provider to see if you
do have a VoiceMail service activated and how to go about
using it.
Per the CS6114 User Manual, the display indication shown,
"New VoiceMail", will be removed from the cordless phone
handset when you have accessed the providers' VoiceMail
system and played/cleared the messages.
If the alert display persists, it can be cleared from the handset
by the following (tested on my own cs6114 phone):
press [menu]
scroll to "Settings"
press [select]
scroll to "Clr voicemail"
press [select]
display reads "Reset VM Icon?"
press [select]
phone will (chirp)
press [off ] [off ]
How do you set up and check your voicemail on a VTech DECT 6.0 cordless phone
VoiceMail is not a function or feature of the cordless phone.
have or can get a VoiceMail service activated and how to
go about using it.
How to check voicemail on my vtech 6.0 phone
go about using it.
OTOH, some cordless phones have an associated Answering
Machine System to answer incoming calls, save a message,
provide for you to access and manage the system remotely
(ie, call-home and play your messages, delete some or all, etc.)
The specific how-to's for all of this are best viewed in the
original Owner's / User's Manual which is easily downloaded
from www.manualslib.com ( look underneath the battery
inside the handset for a small sticker showing the proper model
number to look for ( ie, CS6229 ))
How do I check voicemail
VoiceMail is not a function or feature of the VTech cordless
phones.
go about using it.
"New Voicemail" will be removed from the cordless phone
press [menu]
press [select]
press [select]
press [select]
phone will (chirp) press [off ] [off ]
How to set up voicemail
phones.
can have a VoiceMail service activated and how to go about
using it.
How to check voicemails on vtech model cs6519 - 16
The CS6519-16 isn't a voicemail system. To check the voicemail on the system provided by your telephone company, see pages 14 and 21 of the manual: http://cdn-media.vtechphones.com/media/p/document2/products/%7BE839F72C-D9DC-4CEF-A708-7F251646DAF6%7D/CS6519-16_UM_2_618.pdf
Turn on voicemail indicator on my vtech
On most VTech phones the voicemail indicator turns on when someone leaves a message on the voicemail system offered by your phone company. Many phone companies have such a system, which takes messages when your phone is busy. You'll have to contact your phone company for instructions on accessing their voicemail system.
1helpful
Phone does not ring goes straight to voicemail
hello, its is possible that you have activated your call DIVERT...
Try to deactive all call DIVERT on your phone device.. Go to your settings, check CALLS SETTINGS, THEN YOU CLICK ON CANCELL ALL DIVERT..
cheers.
2answers
How do I SET UP MY VOICEMAIL ON MY VTECH , LIGH IS FLASHING
After you heard the message (suggest you to call your phone company to get your voicemail access code if you don't know your code), then press the "menu" button on the phone, and scroll down to find the "CLR VOICE MAIL" and press OK.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
