Question about Samsung HT-Q100 System
HT Q 100 CHECK FAN - Samsung HT-Q100 System
Hi I've Just been given an Inventek Spiral Saw Kit second hand does anyone know where I can get a manual?
You can view and download the manual from this link . but be sure of your model number first .
http://www.manualslib.com/manual/165750/Stihl-Ht-100-Ht-101-Ht-130-Ht-131.html
May 15, 2015 | Garden
I do not have any spark at my spark plugs this after I replaced my voltage regulator
check ht cap ..check ht lead, check condition of cut out switch, check power coming from coils, check power coming from cdi unit,
Feb 16, 2013 | 1983 BMW R 100 RT
When I turn on the unit I get a symbol that is a circle with a diagonal line through it and then the unit turns off. Any ideas? (Samsung HT XQ100 Home Cinema)
Your fan is bad.
The system is intelligent. It knows it will overheat without a fan. It also knows there is a problem with the fan, so it throws its self into self-protect mode to keep from overheating.
Have a tech check your fan.
;o)
Nov 17, 2010 | Samsung HT-XQ100 Theater System
Samsung HT-Z310 "protect" message!!! How do you fix this? I was told to send it in to Samsung and pay $160...when I bought the HT system for $150!! I don't think so Samsung!! It's not in an enclosed area,...
Does it have a fan in the back? Is it spinning? If it does have a fan that is not spinning, you may be able to replace it. Another possibility is a short in the speaker wiring, check the wires to make sure that a strand or wire is not contacting another wire...
Mar 05, 2010 | Samsung HT-WP38 System
Powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Jun 30, 2009 | Samsung Audio Players & Recorders
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
Cooling fan stopped working.
http://www.samsungparts.com/search/search.asp
try to check all the accessories for your unit here
May 30, 2009 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Samsung ht-q80 won't open tray
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 24, 2009 | Samsung HT-Q80 System
Samsung Surround Sound - DVD Player making noise as if the cooling fan is catching on something
Samsung HT-TZ312 Theater System keeps flashing 'fan check' when i turn on and shuts down after two minutes.
Please Help
Apr 29, 2009 | Samsung HT-TZ312 Theater System
Fan check
Guys, I know this is an old post but I had the same problem recently. Took it to my mate and he said the fan at the back was full of dust which was stopping the fan blades spinning. He sprayed it with compressed air from a can and it works perfectly. Complete fix for only five pounds for the compressed air off eBay
Dec 27, 2008 | Samsung HT-Z310T Theater System
Samsung HT-Q100 System Logo
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
