Question about Disney 13" TV
When i try to play a dvd does not play but give me a question mark
Disney DVD player does not play but give me a question mark on the blue screen top right of screen
5 Related Answers
Anonymous
SOURCE: Dvd will not play movies
If you are getting a blue screen when you try to play the dvd, try this. Hit the input button on the tv remote. A list of items will come up. Hit the input button again and again until you reach the item on the list that says AV. Your dvd should then play just fine. One last thing. Once you get the dvd to play the parental code setting may come up. It says something like the parental code has been set. Select yes. It will ask you for a password. The password is 1369. You should have no problems.
Good Luck
Posted on Dec 26, 2007
Anonymous
  • 3 Answers
SOURCE: disney cars dvd tv combo
all dvd players have region (1,2,3,4,5) you must check on the back for a number inside of planet, to see what dvd you can use(the dvd must have the same number or region than the dvd)
note for us products is region 1
or you can search on internet for a code to convert you dvd player to multi-region
Posted on Oct 31, 2008
Chris Goulet
  • 41 Answers
SOURCE: Disney C1320PTVD TV/DVD Combi. Won't play discs just makes a spinning sound!?
You have to replace the DVD player. The problem is that parts are not available and it's difficult to open the unit. There are about 20 screws to remove, including four screws hidden behind each fender. You have to pry the fenders and rip them off to break two brackets that hold each fender on. The fenders still hold on fine with the remaining seven tabs on each fender. You have to eject the disc to get the mouth off.
I have a working DVD player for sale. It's from a car TV with a defective picture circuit, but the player runs and I hear the movie soundtrack, so I'm 99% sure it's good. I broke the mouth off the player, but it could be glued back.
If you have a good motherboard for sale with a bad DVD player, I might buy the motherboard from you.
Chris
email me: chris_goulet [at] yahoo [dot] ca
Posted on Jun 23, 2009
Shailesh Parikh
  • 83 Answers
SOURCE: my disney TV / dvd player will only play in black
PLS. seting tv in colour sys [exmp. PAL /NTSC/ SCEAM] so
set your colour system is AUTO . the set all colour system automatcly.
Posted on Oct 08, 2009
Chi Chu
  • 8457 Answers
SOURCE: is there a way to get the dvd player to play with
No,try website like Remotes.com to buy an remote same as the original remote.
Posted on Nov 17, 2010
DVD player will not play Disney made movies
I don't know what BOLT is, as I fixed my last DVD player 6 years ago at Sony. I think the Disney Format is Newer than your DVD player can read.
I remember Sony had a $5000.00 when new DVD player that was the first generation of DVD's. We would get them in for repair and the guy would say "My Radio Shack $99.00 plays all my DVD's but this $5K FIVE YEAR OLD unit won't play them....
There was NO fix for the problem. The New DVD's were beyond the capability of the 5 year old unit.
SO.. Is the Disney DVD a Blue Ray Disk? Or a new format that your older DVD can't read?
AL
Apr 26, 2009 | Spectroniq Televison & Video
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
My daughter's disney dvd player wont play disney dvd's any ideas?
I would suspect dirt, either on the disc itself or in the player. The discs and laser head need to be clean to do their job properly. If they are too dirty to operate correctly the machine simply gives up trying as though there were no disc loaded at all.
Feb 26, 2009 | Disney Princess DVD Player
Disney princess dvd player will not play any dvd!
We had the same issue. Try clicking <play>1234<play> and it should unlockk the dvd in the machine. Seems to work on my daughters. It's a parental control of come sort. HTH.
Jan 17, 2009 | Disney Princess DVD Player
Disney Princess DVD player
11/12/08 My 18 yo daughter took her Disney "Ramon" dvd player she received at Christmas yo college with her and I used the code a moment ago <play> 1234 <play> and it unlocked it for her immediately.... try it it might work for you as well! Good Luck!
Oct 29, 2008 | Disney Princess DVD Player
Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Aug 07, 2008 | Disney Princess DVD Player
Car DVD Player not working
hi sounds like its not reading your discs. try giving the dvd a clean and maybe try the DVD cleaning disc.
otherwise next stop repair agent.
Mark
www.blueice-electronics.co.uk
Feb 23, 2008 | Car Audio & Video
Are you trying to play a DVD-ROM? Some sets won't play anything but conventional movies, leaving you to put the disc in a computer to watch it...accordianman
Oct 20, 2007 | Disney 13" TV
Most DVDs won't play only shows blue screen w/question mark on dvd symbol
The only other thing you can try is to clean the lens manualy.. Ok first take off the top of the unit. Unplugged of course! On the left side facing the front where the disc drawer is, should be a small round disc. To the right of that will be a slider assy. with a small lens attached. Take a cotton swab, and dampen it with regular alcohol. In a swirling motion clean off the lens very lightly, easy does it now. Take the dry end and do the same thing. Now wait 2 to 3 minutes and plug in the unit and see if that helped. If it did great close it up and let the kids have a ball. if it did not help, Well im afraid there are other troubles that a servicer will need to do, but this unit most likly is not worth repairing. Good Luck PS please dont forget to rate this response
Oct 16, 2006 | Disney Princess MCP DVD2050P DVD Player
Disney 13" TV Logo
Top Disney Televison & Video Experts
Lee Hodgson
Lee Hodgson
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
