SOURCE: standard deviation and other answers
Standard deviation is outlined here (as well as everything else)
http://education.ti.com/guidebooks/graphing/84p/TI84PlusGuidebook_Part2_EN.pdf
SOURCE: When I go into the 1 Var-Stats menu, I need to
If you are performing 1-variable statistical calculations, that presupposes you have one set of data only. Technically all you need is ONE LIST where the data is stored (ex. L1) . However if you have some data elements that are repeteated, you may choose to create a second list where you enter r the frequency (L2 or other). Both lists must have the same dimension (length).
When you bring up the 1-var calculation menu , the list of data elements is specified on one line (Xlist) and the fequency List is specified on the menu line Frequency. Thus there is no need to enter two lists on the Xlist line.
SOURCE: My TI-84 plus silver edition doesnt allow me to
Pay attention to the name: 1-var statistics mean you have ONLY one list of data. So you cannot use two. However if some data values are repeated you may choose to create a FREQuency list. So at most you have two list, one for the data values and the second for their frequency.
When you use the 1-var stat, specify the list that holds the data value (Xlist) and one the FREQ line specify the list that has the frequency
If your data values are in L1 and L2 or any pair of lists, then you should do 2-var stats. You will get the stats of both lists, you can also perform regressions, etc.
