Question about Makita 10" Dual Bevel Sliding Compound Miter Saw
Makita LS1013 not working, power to the switch, anyone know how to troubleshoot the controller
The cord has been tested for continuity and is okay, no shorts. The switch has five wires, black, white, yellow, red (pink) and orange. Tested the switch (not depressed) from the plug on the large terminal (white) and had continuity on the switch to the white wire and also the red (pink) since it is on the same block in the switch. Tested the switch (not depressed) from plug on the small terminal (black) and had continuity on the switch to the black wire. Tested the switch (DEPRESSED) from the plugs large terminal (white) and had continuity on the switch to the white and red (pink) wires. Tested the switch (DEPRESSED) from the plugs small terminal (black) and had continuity on the switch to the black and orange wires. Tested continuity on switch from yellow and red (pink) wires with switched NOT depressed, got continuity and NO continuity with switched DEPRESSED. Checked the bushings on the motor and they look good.
Posted by Jeffrey on
4 Related Answers
Anonymous
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
Anonymous
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Posted on Oct 20, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: My Makita ls1013 has been having a problem
I would unplug tool and check the condition of the brushes. If they are worn excessively or burnt the tool won't work. Let me know what you find and I will try and help more.
Posted on Nov 16, 2010
Testimonial: "rowdy45176, provided me with some very useful info. After I purchased the new brushes then the saw worked perfectly. Thanks again."
rowdy45176
David Ford
  • 2176 Answers
SOURCE: how do u change out bushes on a makita ls1013
there are 2 black screw caps on the outside of the tool that need to be removed. USE a good quality blade and right size to avoid chipping the caps. UNPLUG TOOL first and remove the old ones and replace with new and reassemble. They might arc for a short period of time depending on the commutator wear. Run at NO LOAD for about 10 minutes. Let me know if you still have a problem
Posted on Apr 17, 2012
How to work makita ls1013 without controller device? If this is possible I need the role of wire connection. Thanks to experienced friends
https://www.google.com/search?q=How+to+work+makita+ls1013+without+controller+device&oq=How+to+work+makita+ls1013+without+controller+device&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Apr 06, 2021 • Makita Saws
Makita LS1013 110V feels underpowered. What could have caused this? Brushes are barely worn.
How underpowered? running at half speed? If so check the wiring in the 110v plug. I have seen saws come into the workshop where 1 of the wires is connected to earth pin this results in 55v being fed to saw hence 1/2 speed. Is there heavy arcing at the commutator? if yes armature probably blown. If not still worth examining armature for discolouration, examine field coils at same time if everything seems ok then a possibility is the controller. You could try by passing the controller and if saw seems to run better then you know you need a new controller. It is located at the back of the motor. If you are not sure about electrics do not try this you may electrocute your self or blow the controller.
Feb 21, 2014 • Makita Saws
2helpful
My Makita ls1013 has been having a problem running. It is not turning on at all. I just replaced the switch and it is still not working, I have checked and there is power to the switch. Please help
1helpful
Hi all I have a Makita LS1013 that I got from a friend. I am trying to repair the switches in the handle as they are blown. I have the replacement parts I need to do the job. However someone seems to have...
gdoran681, The information I sent you should have the wiring you will need. Let me know if you have just the LS1013 or if it has the lights on it (LS1013FL)
Rob Popp
Phoenix Repair
I REPALCED THE TIMER CONTROL AND MY DRYER WILL
Always check to make sure you have power at the unit. If power is present and you replaced the timer control there is something else causing your unit not to fire up. I will assume your unit is an electric dryer. Before you check anything inside the dryer make sure your power cord is unplugged. Then check the door switch for continuity. If the door switch test okay then check the thermal fuse located on the blower assembly. Remove one lead and test for continuity, if okay then check the upper limit on the heating box. Again, this is a continuity check and again remove one of the leads before you check for continuity.
Sep 15, 2009 • Dryers
MOTOR IS NOT WORKING
You could try blowing some compressed air into the area around the switch and see if it helps.
Otherwise, it's most likely the cord or the switch.
Can you check to see that you actually have power to the switch. If yes, and you feel adventurous, then first remove the blade, then bypass the switch, (using a power strip as a cord switch) to check to see that the motor works, in which case it must be the switch...they do go out.
Here's a link to parts for your saw: http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1013F.pdf
I hope this helps you to resolve this problem. If there's anything more I can do to help, please don't hesitate to write back...
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
A makita 9227C does not work
Hi, Unfortunately there is no external test, It has to be opened and troubleshot with a multimeter. Especially something with a variable speed controller, power cord, brushes, switches, ect. It could be several things. If you are technical enough to take it apart let us know we will try to help. Good Luck to you!
2helpful
2answers
Makita LS1013FL manual missing
Yes go to Makitausa.com and type in your model number and you can download an owners manual for the tool. Let me know if you need any more help
Makita 10" Dual Bevel Sliding Compound Miter Saw Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
