Sony PlayStation Portable (PSP) Console Logo
Question about Sony PlayStation Portable (PSP) Console
Witch button on the playstation3 is the aoss button
On the playstation 3 witch button is the Aoss button
Posted by ferdi frederick on
4 Related Answers
Anonymous
  • 243 Answers
SOURCE: Can't find AOSS Button in psp
you are doing it in the wrong menu. you are setting up a connection to location free player
you need a wireless connection. And so after that, you go to the internet icon,and then you just type in your link.
1. Go to the Main Menu of your PSP.
2. Go to Settings.
3. Scroll down to Network Settings and Press the X button.
4. Select Infrastructure Mode.
5. Select New Connection.
6. Name the connection so that you know it is for web browsing. (ex. WebConnect)
That way you can use another connection for the rest of your online games.
7. Push the Right Direction Key to go to the next menu.
8. Select the Scan option and let it pick up your WLAN settings.
9. Once it picks up a connect, Push the Right Direction Key to go to the next menu.
10. Select Custom for the Address Settings.
11. Push the Right Direction Key to go to the next menu.
12. Leave IP Address Setting on Automatic.
13. Push the Right Direction Key to go to the next menu.
14. Select Manual for your DNS Setting.
15. Push the Right Direction Key to go to the next menu.
16. Enter in 67.171.70.72 as your Primary DNS and just leave the Secondary DNS blank.
17. Push the Right Direction Key to go to the next menu.
18. Select "Do Not Use" for your Proxy Server settings.
19. Push the Right Direction Key to go to the next menu.
20. Push the Right Direction Key to go to the next menu.
21. Push the X button to save your settings.
22. Do a quick test of the connection to make sure it's working correctly. first you need to have a wireless internet at home. next you need to turn on the wlan on your psp, located at the left side corner of your psp. search for a wlan around you. if its not secured, your lucky, you can connect anytime, but if it has a wep key, you need to find out the key to be able to connect. Switch the wlan button (located on the left side) to on and if don't aoss router seperate from the psp you cannot use automatic. So goto new connection and press scan. Follow on screen instructions.
If you do have an aoss router press button on the aoss router inself so the psp can find it.
Okay now that ive given you your answer make sure to follow fixya's system. Instead of taking the answer and running.
THANK YOU,
NATE
Posted on Jun 17, 2008
Anonymous
  • 86 Answers
SOURCE: WHERE IS THE AOSS BUTTON O A PSP
The psp doesnt have an aoss button- this is located on your reuter but very few reuters have this feature.
Posted on May 27, 2009
Anonymous
  • 60 Answers
SOURCE: PlayStation 3 40GB System: what is the AOSS button on a ps3?...
when it asks this, press and hold PS button in middle of controller
Posted on May 07, 2010
Anonymous
  • 219 Answers
SOURCE: what is the aoss button on ps3
The AOSS button is actually the button on your wireless router (Front/Top). When you go to set up your wireless connection, prior to advancing from the WEP Key screen hit the button on your router which puts it into Network Discovery mode. You should be good to go from there. If not, please see my profile and refer to the few previous posts to get more detail.
Respectfully,
Don
Posted on Jun 17, 2010
Aoss is not a Button on your ps3 it is a button on your router if it has the feature. usually a buton that lights blue after holding down for 5 sec
What is the aoss button
The AOSS is not such a button but more a feature of your wireless router. If you enable this you must make sure that your router is compatible with it AOSS. It is kind of like a special kind of wireless signal that only certain routers and devices can use. It is likely that you will have a standard wireless router rather than one that supports AOSS but if you have a router that supports AOSS you can use it as it is a little more secure than a standard connection.
Hope this helps
1helpful
What is the aoss button on ps3
Respectfully,
Don
1helpful
I need to know were the AOSS button on the ps3
It is asking you to push the AOSS button on your router, not your ps3.
1helpful
Aoss button 4psp
the aoss button you go to network connection and you go to adomatic sorry but then it will say aoss press the right button
4answers
AOSS BUTTON?
its on the on your left side
8helpful
5answers
What is the aoss button/
To set up Wireless correct? Well apparently there is none and you have to set up the wireless connection manually, you do this by going into your network settings. This is where you set up your network options.
43helpful
5answers
AOSS BUTTON ON PS3
i want to hook up my playstation 3 to the net work and this thing comes up and says connect to aoss where is that?
Top Sony Video Game Consoles & Games Experts
Marvin
Marvin
ELECTRICKSUSA
ELECTRICKSUSA
Steven Wander
Steven Wander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
