Question about Pioneer VSX-D510 Receiver
Pioneer vsx d510 power off error
Turn's on a few second's later say's powering down...
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: PIoneer VSX-D510 power issue! pleas help!
Must be the protection circuits kicking in. One or more amp channels must have blown.
Posted on Feb 02, 2008
Anonymous
  • 319 Answers
SOURCE: I turn on receiver Pioneer
Check all speaker wiring for shorts. If nothing is found, unit obviously has circuit problems, have serviced.
Posted on Aug 14, 2008
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: i turn on my Pioneer VSX-D509S 5.1 surround amp
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
Posted on Jun 24, 2009
Gustavo M.
  • 30 Answers
SOURCE: pioneer vsx-d510 coaxial dvd connection problem
I recommend you use an optical connection. Your VSX-D510 has only one optical input, but I believe it is assignable. Use a good optical cable and connect directly to your DVR. Follow the manual to assign the input and it should work.
Good luck
Posted on Aug 02, 2009
ED GUNN
  • 16 Answers
SOURCE: Pioneer VSX-517 was turne up lou. Showe
THERMAL SHUTDOWN PROTECTORS MAY BE BLOWN
Posted on Nov 03, 2009
Pioneer vsx-d510
Disconnect all the speakers, and then check. Connect the speakers, one by one, and find which one makes it overload. That speaker is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Pioneer Audio/Video Home Theater Remote...
How do I get the powered subwoofer to work with a pioneer VSX-D510
You plug a subwoofer RCA cable into the Subwoofer Preout from the back of the VSX-D510 and to the input on the back of the subwoofer. If there is a red / white connection don't sweat it, just use the red. Should work fine.
Feb 14, 2016 | Pioneer Audio Players & Recorders
How to hook it up with sub dvd
Not sure what a "sub dvd' is but here's the manual. The Subwoofer Pre Out would provide a Line Level feed for a powered subwoofer, once it is configured to do so.
Page 14.
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
Jan 30, 2011 | Pioneer VSX-D510 Receiver
PIONEER AMP ERROR
Most probably you have one of the power amplifier modules bad. They are the PAC010 and PAC011 type. You can remove one and power up the receiver. If it powers-up normaly it's that one.... (50% chance) Otherwise remove both and it should power up normally. Beware that these parts are expensive... Most times just with a new part the problem is solved. YMMV. Good luck
Jul 14, 2009 | Pioneer VSX-D510 Receiver
Pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Dec 18, 2008 | Pioneer VSX-D510 Receiver
Weird issue with Pioneer VSX-D510 and "tone"-setup
clean the all push buttons by using isoprpylalchohol.(surgical spirit)and dry well .i think all the buttons are short by itself.the problem is still there please check the power supplu secondary side smoothing condencers related to system control power section.
nuwan
Oct 02, 2008 | Pioneer VSX-D510 Receiver
Feb 01, 2008 | Pioneer VSX-D511 Receiver
Pioneer vsx-d510 coaxial dvd connection problem
Good luck
Nov 16, 2007 | Pioneer VSX-D510 Receiver
Pioneer VSX D510 Reciever (power supply or the main amp circuit problem)
I'm having the same problem. I read on a kind of VSX-D510 eletronic manual tha says POWER OFF "When displayed, it's the case where DC is in the output of AMP".
Do you know what does it means? How can I solve the problem?
Aug 21, 2007 | Pioneer VSX-D510 Receiver
Pioneer VSX-D510 Receiver Logo
452 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
