Epson Expression XP-305 Inkjet Multifunction Printer - Colour - Photo/ Logo
s
satish lokhande Posted on Jun 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fs1020 has aproblem code e0001 - Epson Expression XP-305 Inkjet Multifunction Printer - Colour - Photo/
Printer Help & Support
Level 3:
  • Epson Master 783 Answers
  • Posted on Jun 25, 2014
Epson Master
Level 3:
Answers
783
Questions
0
Helped
279923
Points
1637
A E0001is a fuser error code. You may have had a power surge and the copier got confussed and coded out. You will need to reset the error code in service mode. If it can not be cleared, you may have a problem with the fuser unit
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
3answers
When i start my fifa 12 i get E0001 error
Do you also get any 'beeps'? If so how many and what pattern (if any)?
2helpful
Error code e0001 for fifa 12
how tou remove the error e0001 ?
3helpful
2answers
I cant start my fifa 2011, shows me E001
Fifa 11 Demo PC E0001 Error Issue
Fifa 11 E0001 error happened to a PC with this or a similar Specs: Pentium dual core, integrated Intel graphic card, 1GB of RAM, 128 of vid RAM, 2.0 pixel shaders.
Fifa 11 Demo PC E0001 Error Issue Fix:
1. Fifa 11 requires a shader model 3 or better card. That is error E0001 will be fixed and you can play this game again.
So if you get an error message as E0001 while playing Fifa 11 on Windows 7 or other systems, you should first set to the shader model 3 of your card.
2. This E0001 error issue may also be related to the graphic card that you are using. Check the drivers you are using for the video card. Update and reinstall it if necessary.
3. Get the latest driver pack for the same and then process out for the implementation. You can download the current new AMD catalyst 10.9 graphics card driver here. Or NVIDIA ForceWare 260.63 driver if you are using a Nvidia card.
4. Change the resolution to have a try. Some users get the E0001 error fixed for Fifa 11 by trying the 1280x1024 resolution on his computer.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
3helpful
My fifa 11 no working e001 problem
1helpful
Error E0001 004
A E0001-004 is a fuser error code. You may have had a power surge and the copier got confussed and coded out. You will need to reset the error code in service mode. If it can not be cleared, you may have a problem with the fuser unit..... Good Luck
1helpful
I installed FIFA 11 on my PC and when I run it it comes up with a box say 'E001'.
1helpful
2answers
E0001 problem while starting demo version of game
This game requires a shader model 3 (or better) card.... that is error E0001
For more details refer the below link
http://tinyurl.com/e0001
4helpful
2answers
When i start my fifa 11 then it can't start its writting E0001,what shoul i do?
Lol just change your resolution and then change back....worked for me
6helpful
I INSTALLED FIFA 11....BUT WHEN ISTART THE GAME IT SHOWS E0001 ERROR..........PLS HELP ME........
E0001 ERROR -> Fifa 11 requires a "Shader Mode 3" or better card. That is error E0001 will be fixed and you can play this game again
You can try updating your graphic cards to the latest drivers from Manufacture Site, update your DirectX to the lastest too. If the problems is not solved, then you have to get a better card in order to play the game.
FYI
Chipsets used in models:-
NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300,
ATI Radeon HD3200, HD4350, etc.. and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps.
2helpful
3answers
I installed Fifa 11 When i start it, a dialog box appears stating "E0001" whats the probem and how to solve it?
This is due to your graphic card not supporting "Layer 3 mode or better". You need a better graphic say with "layer 4 mode" support to play the game.
FYI
ATI Radeon HD3200, HD4350 and
Hope it helps.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
