Question about Onkyo TX-DS575 Receiver
I have 5 "Nitsuko grouphone TX series" landline phones which have echo problem (isolated the problem using new 10$ phone which doesnt have echo problem) is there any fix? we are a small business and t
Its a landline phone. I am preety sure the problem is the phones and not our pabx system. I dont know if there are settings have tried to google some up. I tried to look for a manual or a fix for the echo problem. some help would be great "Grouphone TX series: NX.E-6TXD TX SERIES-1.A"
Posted by dave on
3 Related Answers
Anonymous
  • 151 Answers
SOURCE: Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: TX-DS474 settings clear when power is switched off
That's what the standby button is for. The "master power" button should only be turned off if you are going to be out of town for months at a time. If you use a good surge protection unit like monster or panamax, there is no reason to turn off the master power. It only draws about 200milliamps of current to keep its memory. About as much as a clock radio when its off. Hope this helps
Posted on Jun 23, 2009
Anonymous
SOURCE: I have an Onkyo tx-sr605 7.1 channel receiver in
After a long effort searching on Google, I found a solution. There is a Late night setting on the remote that limits the loud sounds scenes so it is not much loader than the dialog. Works great, I can't believe I never notice the button before.
Posted on Jan 20, 2010
Why my nitsuko tx serise nxe2464m tx extension phones are not riging
Ringing is assigned in system programming, either a tech or your office in house tech will need to make the change.
Reprogramming speed dial on old Nitsuko phone
Helo libbyc,
What is the model of your Nitsuko phone?
1helpful
How do I access my voicemail from another phone?
To call your Voice Mail from a landline phone:
1. Call your TracFone from a landline phone.
2. When your voicemail begins, press the star key on your landline phone immediately.
3. Enter the PIN you use to check your Voice Mail from your TracFone. When you have finished entering your PIN, press the pound key.
4. Listen to the instructions. They will tell you how many voicemail messages you have and give you options for checking them, deleting them, saving them or storing them as new messages. Phones may vary, so listen carefully to the options.
if you havent created a pass code try 9999, if that doesnt work give tracfone a call.
1-800-867-7183
1helpful
My nitsuko old model phon with pbx system want to reprogram, pls advise sakir ahmed
I am looking telephone set for nitsuko model 206G for purchasing or another model telephone set can be use
1helpful
Hope this helps.
CABLE GUY.
Onkyo TX-DS575 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
