Question about Rotel Audio Players & Recorders
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
I HAVE THIS ROTEL AMP AFTER PLAYING IN MEDIUM LOUDNESS FOR ALMOST 10 MINUTES THE RIGHT SPEAKER CHANEL GOES OFF BUT NOT COMPLETLY (YOU CAN HERE MUSIC VERY LOW AND WITH A LOT OF BACKGROUNG NOISES
Posted by AK47 on
Pieter Vleeshouwers
  • 2,016 Answers
BUY a canister coldspray and spray on some circuitparts that will be come up again back if you have sprayed on the thermal defect part
Posted on Nov 19, 2016
Teb Pixels
    New Friend:
Clean or change the relay.
Posted on Mar 14, 2015
Paolo Torres
    Master:
  • 485 Answers
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Posted on Jun 14, 2014
Testimonial: "the speakers work dhecked with ather amp"
  • Paolo Torres Jun 15, 2014
    With what source are you driving your Rotel amp? Have you checked the input connections? Have you tried doing something with the controls? You must have something wrong with one audio switching IC, otherwise.
  • AK47
    AK47 Jun 18, 2014
    after working it for a few days the problem seems to be fixed
Idealistic graphic equaliser model 31-9081
Connect your Denon outputs to the Realistic main inputs.
Connect your Realistic main out to the Rotel tuner in.
Connect your Technics out puts to the Realistic Tape 1 inputs.
Connect your tape 1 out puts to your Rotel cd inputs.
And you should be good to go.
May 02, 2016 | Audio Players & Recorders
Rotel RA 12
I think RA 12 is not existing type, but RA 12xx types exist.
Please try this link, and I hope you will find the relevant documentation.
gylacz
Mar 18, 2013 | Audio Players & Recorders
I have a rotel rb970bx. I have 2 and ran them in mono driving a speaker each. I tried to biamp the speakers with one amp driving the tweeters and one the woofers. This worked for about 4 minutes at 1/4...
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Dec 21, 2017 | Rotel Audio Players & Recorders
Manual circuit diagram
I don't believe that Rotel service manuals are available outside of authorized service centers. Can you provide us with the problem that you have? Perhaps we can guide you through the repair.
Thanks,
Dan
Sep 20, 2009 | Rotel Audio Players & Recorders
Need manual for ra 840bx4 & wattage output when remote speakers?
Lets try the simple stuff first. This whole problem could be caused by a dirty switch contact. Pick up some electronics cleaner from a local electronics shop and spray the switch (from the inside of the unit). Work the switch on/off a number of times then respray one more time. That should clean out any dirt that is there. Try the unit again and hopefully the problem is resolved. If not, then the switch itself may need to be replaced. When you get the cleaner, get one that contains a lubricant as well. This will help to prevent the problem from coming back again.
Dan
Jun 20, 2009 | Rotel Audio Players & Recorders
Rotel power amp
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
May 20, 2009 | Rotel RMB-1095 Power Amplifier
Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Nakamichi AV-7 Receiver
Problem with Rotel RA 870
Since it is a Rotel, it is a good unit and worth fixing. At this point, you need to take it to a good repair shop and let a qualified tech look at it. There are no user serviceable parts inside and if you go poking around in there, you WILL make the problem worse. Rotels' are nice units and represent a good value in stereo gear. Take it to a reputable repair shop that repairs Rotel under warranty. If thats not available to you, then a good repair shop should be able to get you going. Good luck...Rob
May 09, 2008 | Audio Players & Recorders
Rotel ra-820 amp speaker ports dieing
You may have blown a fuse on the left channel due to speaker wires shorting or a defective speaker. If there are no fuses on the rear of the amp there are probably internal fuses. They are usually glass with a small wire running from end to end. If the fuse is blown the wire will be broken. Replace with the same value of fuse.
Aug 27, 2007 | Audio Players & Recorders
330 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
