Nokia 6288 Cellular Phone Logo
Question about Nokia 6288 Cellular Phone
Nokia 0168 is charging very slow
My nokia 0168 has started asking me to select moderm mode orsync and connect or memory every time I plug a charger in and is taking days to charge to 100 percent and says no response from host everything else is fine
5 Related Answers
Anonymous
  • 490 Answers
SOURCE: charging problem
problem is with the hardware of the handset so visit nearest nokia care . or visit http://nokia.com to get info about ur handset problem
Posted on Oct 10, 2007
Anonymous
  • 67 Answers
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
Posted on Dec 21, 2007
Anonymous
  • 8 Answers
SOURCE: NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Posted on Feb 16, 2008
Anonymous
  • 75 Answers
SOURCE: nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
Posted on May 27, 2008
Anonymous
  • 1952 Answers
SOURCE: nokia 2300 charging problem
just adjust or change the pin in mob
Posted on Feb 23, 2009
My nokia corporation 0168 mhave security code
How can i reset the security code of my nokia ce0168 ...
www.askmefast.com > ... > Code
... nokia ce0168? How can i get back my security code in my nokia asha ce0168 ....Ce0168 model 201 type rm 799 nokia 201 master code · Master reset code ...
Forgot the security code of nokia 0168? - Ask Me Fast
www.askmefast.com > Computers & Internet > Security > Code
You can get the master rese ... read more .... Code de reinitialisation nokia corporation 0168 ... Factory reset for lg ce 0168 and can t remember security code.
Nokia c e 0168 security codes - Cell Phone
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
My nokia n73 having quite problems like you know very slow and not so much fast as others nokia sets. Always internet will be blocked or shows connection error while browsing please help.
first free your phone memory by formatting it .... code is *#7870#.... note you shold have full charged battery and the phone should be connected to charger......... phone will restart and formatting may take 5 to 10 minutes........ this will free all your phone memory.......... now install the browser you use.... i.e opera mini....... in phone memory......... dont fill your phone memory........its the ram you utilise......... your phone will work faster......... it is slow from other nokia multimedia sets because it has a maximum ram of 44 mb that to can be used to a extent of 30 mb......... also use netquin mobile guard to enhance your phones performance
2helpful
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
computer
You can use the following methods to transfer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
files, make the connection with a compatible USB
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Hi, i have problem with my n73 cell and it is very slow in opening the features and sometimes it will appear " memory full delete some data" even if the memory s still spacious. i want to...
Download and install Nokia PC Suite and Nokia Software Updater available from Nokia.com, once installed use PC Suite to backup everything you need on your phone...
Make sure a working sim is inserted into the phone and General profile is selected, plug in the charger and turn the phone on, once fully started plug in the USB cable and run Nokia Software Updater, it will pick up the phones current version and download any updates...
Not charging
plug is bad or the battery is bad one of these 2 things need to be replaced if you have a car charger try that it will let you know if your battery or charger needs to be replaced
car charger will start chargin battery
May 10, 2008 • Nokia 1100
2answers
Charging problem
It's either a software fault or hardware failure. Backup everthing you want to keep then download and install the nokia software updater: www.europe.nokia.com/softwareupdate If this doesn't fix it then you will need to visit a nokia care point. Care points: http://www.nokia.com and select your country.
Top Nokia Cell Phones Experts
Kolbrun...
Marvin
Marvin
matt
matt
