Question about Xante Ilumina Digital Color Press Printer
Yellow sensor error - Xante Ilumina Digital Color Press Printer
Cyan ATC sensor failure. Error code 14. I replaced developer and did ATC sensor setup. Still having issue.
Yellow ATC Sensor Failure,Code12
Magenta ATC Sensor Failure,Code13
Cyan ATC Sensor Failure,Code14
The ATC Sensor detects an insufficient amount of developer.
Note
If this failure reoccurs three times successively, an Engine NVRAM value is set preventing further printer use until the Clear Tech Rep Fault (see pg.6-20) is performed.
Troubleshooting Procedure
Step Actions and Questions Yes No 1 Is the problem toner and/or developer empty. Replace the toner or developer. Go to step 2. 2 Is the ATC sensor clean and free of dust, toner or any other contaminates? Go to step3. Clean the ATC sensor. 3 1.Check the ATC sensor wiring harness Yellow=P/J129
Magenta=P/J130 Cyan=P/J131
2.Is the wiring harness or the sensor defective? Replace the ATC Sensor and/or wiring harness. Go to step 4. 4 1.Remove the Rear Cover and RearShield.
2.Measure the voltage at...Yellow=P405B3 Magenta=P405B8 Cyan=P405A10
on the engine control board.
3.Is the voltage between+1 and
+3VDC? Replace the engine control board. Go to step 5. 5 1.Measure the voltage at...Yellow=P405B14 Magenta=P405B11 Cyan=P405A11
2.Is the voltage+5VDC? Replace the engine control board. Go to step 6. 6
1.Measure the voltage at...Yellow=P405B2 Magenta=P405B9 Cyan=P405A9
2.Is the voltage 0VDC? Replace the engine control board.
Go to step7.
7
1.Remove the Imaging Unit Plate cover.
2.Inspect the wiring harness between the engine control board and the developer housing assembly.
3.Is the wiring harness defective? Replace the wiring harness.
Replace the ATC Sensor.
8
Run approximately 10 pages of the solid fill full-page prints for this color to ensure the error is cleared.
Mar 12, 2015 | Xerox Phaser 7750 Laser Printer
Tip
How To Remove 077-100 Error in Dell 3130cn Printer?
This is right that error 077-100 error is belong to Registration and or Exit sensor.
But if the yellow toner cartridge doesn't run so there will jamming the paper and the printer shows the error (077-100).
Actually i solve the issue after three days when i guessed and checked the yellow toner cartridge it was tighter than others.
So i replaced the yellow toner cartridge and solved the issue.
on Mar 29, 2016 | Dell 3130cn Color Laser Printer
Error c2556 in konica minolta bizhub c 200
C - 2556 Abnormally high toner density detected yellow TCR sensor.
Clean the TCR sensor window on the underside of the yellow imaging unit if dirty.Reinstall imaging unit or change imaging unit.
Apr 01, 2013 | Office Equipment & Supplies
Canon iPF610 hardware error 03800500-2F2F and 03800500-2F30
03800500-2F2F/03800500-2F30 Head management sensor error
0014-0999
The head management sensor detected an ink discharge error.
A sensor sensitivity error was detected during head management sensor position adjustment.
Print head, head management sensor, or main controller PCB
1) Replace the print head.
2) Visual check
Remove foreign substances from the head management sensor if any.
3) Replace the head management sensor.
4) Cable continuity check
If continuity of the cable between the head management sensor and the main controller PCB is abnormal, replace
the cable.
5) Replace the main controller PCB
May 30, 2012 | Canon iPF610 InkJet Plotter Printer
HI, Does anyone know a clearance for a Konica Minolta Bizhub C35 with error code 0F52, thanks
Yellow Toner Sensor malfunction. Check connectors on PRCB, inspect/disassemble/reassemble/reinspect yellow toner sensor assembly, or possibly replace PRCB.
Source: service manual.
Credentials: I am having this same code right now.
Feb 17, 2012 | Office Equipment & Supplies
We have a CL7000 which comes up with error message SC375 & SC387. What does these relate to.
sc 375= Vt error [Yellow] (toner density sensor error)
sc 387=Development gamma error Yellow
it looks like there is a problem with your yellow development unit.
it may not set in properly or needs to be replaced.
Jan 15, 2010 | Ricoh Aficio CL7000 Laser Printer
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
54.15 error code
Error Code 54.XX
Control Panel Message: Printer Error
Description:
15 Yellow CPR sensor
Recommended Action: Turn the printer off and then on, and then check the following itmes
Check the connections. Replace the color-registration detection assembly.
Description: Printing cannot continue. There is a sensor malfunction.
XX Description
15 - Yellow toner remaining sensor (J1014 toner level sensor)
Jun 24, 2009 | HP LaserJet 4700 Printer
Dell 3010 cn error message 093-960
Try reseating all the toners. Often times when one isn't seated 100% correctly it causes errors in others. Typically the black cartridge affects the Yellow sensors.
Feb 19, 2009 | Dell 3010cn Laser Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
59 people viewed this question
Top Xante Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
