Question about Hotpoint Ultima WF865 Front Load Washer
It keeps coming up Test on led screen
When selecting programme it automatically comes up test on led screen, no water comes through but drum goes round for a few seconds.
5 Related Answers
Anonymous
SOURCE: Hotpoint ultima wf860
hi, i have the same machine..i have a feeling it does this annually to make you call an engineer. to reset it do this; hold the 'start' button until all lights display, then press 'start' again. hold the 'start' and 'on/off' button together until it reads d-end or d-off. it doesnt always work 1st time so keep trying, good luck x
Posted on Nov 14, 2006
prem mathew
  • 1294 Answers
SOURCE: "Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Posted on Dec 02, 2007
Anonymous
  • 100 Answers
SOURCE: my hotpoint washingmachine WF860 comes with the message tESt
it's on test mode for the factory. this comes on if you hold the on and start buttons together. can be reset by turning on while holding both on until dOFF appears.
Posted on Jan 27, 2009
Anonymous
  • 100 Answers
SOURCE: my hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
prem mathew
  • 1294 Answers
SOURCE: keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Posted on Mar 08, 2009
When I attempt to print the data and ready lights are on, but soon after it sounds as though it will print, the "Alarm" light appears, and printing stops.
Go into Test Print Mode
The printer incorporates various test print modes.
Select the test mode you want to use following the steps below;
(1) Turn off the power switch of the printer and check that the front cover is closed.
(2) Turn on the power switch while holding down the control panel button. Press the button
until the Drum LED comes on.
The Drum LED illuminates to indicate that the printer enters into the test print mode.
(3) If you want to execute the test print, release and then press the button again when the
Drum LED comes on.
or
Push "alarm" button : The printer is restored to the factory setting and permanent fonts and macros are cleared.
The printer returns to the ready status after
printing.
If it does not reset, replace the main PCB.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 23, 2011 | Brother HL 1440 Laser Printer
Red Alarm light (and all others) flashes, does not print. Closed properly. Seems to be a small amount of toner left in cartridge.
Drum LED comes on.
or
printing.
Thanks, Joe
Feb 22, 2011 | Brother HL 1040 Laser Printer
I have a hotpoint wf840 everytime i enter a wash cycle it just says test and performs a spin cycle whilst test still comes up on the screen is there anything i can do other than buy a new washing machine
May 05, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
My washing machine Hotpoint wf860 keeps showing Test. please help
The appliance appears to be in shop test mode, to de-activate it follow these steps.
there is 3 differnt variations so here are all 3.
Press the Start/Cancel button until all the console LED's illuminate.
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
These variations could explain why some of us have to make several attempts to clear tESt.
Apr 06, 2010 | Hotpoint Ultima WF865 Front Load Washer
Every time we try to wash it comes up test and goes through a test cycle. Will not wash. Hotpoint WF860
Nov 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 comes up with test all the time
Press the Start/Cancel button until all the console Led's Illuminate
Normal screen should return and you can select a new programme. (GL = good luck)
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Keeps going on test cycle
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf865
press on off button till test comes up then press on off and start cancel button together for a few seconds
Jun 26, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WF640P - in permanent 'test' mode?!
Press "start" & "on" together for over 5 seconds; the test mode will come off.
Dec 09, 2007 | Washing Machines
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
41 people viewed this question
Top Hotpoint Washing Machines Experts
James Hehling
James Hehling
Level 1 Expert
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
