Question about Hayward Pool & Spa
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Posted on Apr 23, 2010
SOURCE: sta-rite pool heater won't fire...
nomoneytom did you find solution if so let me know I have same issues. Thanks
Posted on Jun 06, 2010
SOURCE: Sta-Rite Max-e-Therm pool heater shows error code
These pool heaters have a detailed users manual that has a great troubleshooting guide. I would try there first. They ask alot of questions that you have to be looking at the heater to answer. Here is a link to an online version.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 16, 2010
Jun 27, 2014 | Sta Rite STA-RITE CONTROL BOARD KIT -...
May 04, 2013 | Pool & Spa
May 12, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Aug 26, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
191 people viewed this question
