Question about NorStar M7324 Telephone
How do i make my m7324 ring? - NorStar M7324 Telephone
How do I make one extension on my Norstar M7324 phone system ring?
Hi J,
Do you mean how to make it ring when someone calls a specific phone number, or when someone calls the specific extension?
If for a phone number, then you need the line to appear and ring on the phone. Let me know which one you're doing.
May 14, 2014 | NorStar M7324 Telephone
Northstar M7324 has to change battery? all sudden one of the phone cannot dial out nor ringing tone
Sounds like a bad phone. None of the M series phones have batteries that need to be changed. Swap the phone on another extension with the same type of phone. If the trouble follows the phone, then the phone is bad, and if it stays at the same location then the port on the phone system is bad.
Oct 19, 2013 | NorStar M7324 Telephone
Can I change the ring tone for just one of the lines on my nortel norstar phone m7324?
If your phone system has 6.1 software or up then yes,the tech or vendor can program it for you. If you know how to program look under Config/Lines for Ring Type.
Oct 17, 2012 | Nortel M7324 Refurbished Norstar System...
Norstar m7324 won't come off night ring
Is the button still programmed?
Do F871 in meantime....F#871 on older systems helps too or just F87.
Program button:
F*3
button
Feature
871
Jul 23, 2012 | NorStar M7324 Telephone
How do i make all lines ring at certain desks for a norstar m7324 phone?
Programming2_bing.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Apr 21, 2010 | NorStar M7324 Telephone
Old reception phone now regular office - reprogram
Programming is done on M7310, M7324 and T7316 sets.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should say line 001: appear& ring
press the Chng key till it says appear only
The display should say line 002: appear &ring
Oct 26, 2009 | NorStar M7324 Telephone
I need to make them ring
First check and see if the ringer is on or the volume is turned up.
1st press Feature *6 Press number keys 1- 4 to hear different ring types
2nd - check your volume (Press Feature *80 press volume key up or down
Jun 23, 2009 | NorStar M7324 Telephone
Phone does not ring
You have to go in to installer programming to make the phone ring . Press feature ** 266344 the system will then ask you for a password just re-enter 266344 . Next if you have the old software you need to go in to config,show stations , line access ,ring and change to y for yes , if it is the newer software you start at terminals and sets . If you have any ? you can call me 626 712 5753 pacific time .
Jan 27, 2009 | NorStar M7324 Telephone
MERIDIAN M7324
Do you know how to program the system?
You will need to log into system programming. Got to lines/trunks and enter your extension. You will see the line appearances to appear only. You need to change those to appear and ring.
If you do not know how to get into programming. Call a professional.
Jan 07, 2008 | NorStar M7324 Telephone
NorStar M7324 Telephone Logo
20 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
