Front wheel bearing
Pull wheel remove grease cap undo carter key remove nut pull off rest of hub take bearings frt and rear out of hub clean old grease from bearings check bearing for defect install in revers order remender to install new grease in new bearings lots of grease and u will need new seals for same front and rear
SOURCE: replace front wheel bearings
Its pretty simple.
1. take off wheel
2. take off brake caliper, caliper bracket, and rotor.
3. remove axle nut which secures axle into the bearing
4. should be 3 bolts on the flange which hold the whole wheel bearing/hub unit on.
5. reverse for reassembly
The wheel hub and bearing are all one assembly and are bout as a unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: 2000suzuki Esteem front wheel bearing R&R
start by jacking up car end of cv will have a cotter pin remove it, you'll need a 35 mm or 1 1/2 sae socket to remove retaining nut , after that ues a hard block of wood and strike that with hammer ( NEVRE STRIKE CV END WITH ANYTHIN METAL OR VERY HARD),at this point cv should be loose ,seperate cv from bearing hub you may also have to remove tie rod end to swing it out.ok thats it in a nut shell good luck hope it helps you.
