Question about Swingline Optima Electric Stapler 45 Sheet Capacity Silver
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Posted by Dale Waters on
Wayne Lee
    New Friend:
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Posted on Nov 06, 2014
  • Cheryl Carter Dec 09, 2019
    Thank you. How do you check the spring to see if it isn't seated correctly? Is there a way to get it apart to see the seat? It doesn't jam every time, just on occasion. The slide that the staples are in will stop in the down position and it is really hard to get it pushed back up again.
  • Thomas Chandler
    Thomas Chandler Jun 13, 2020
    i have same problem and trying to get into that slide seems like a major task even if possible..I have disassembled the stapler removing top and bottom and separating the sides with the 4 hidden screws but that slide sits in the middle of the stapler assembly and its difficult to get to .. the plastic slide have some wires from the circuits glued and screwed that interfere with complete separation of the sides to be able to work on that inner assembly.
My Swingline Optima 20 electric stapler will not release the tray to add more staples. How can I fix this?
Most likely a staple is jammed near the discharge end. Get a small screwdriver or pick and try prying out any stuck staples. Usually a little force will pop the release tray out.
Oct 02, 2018 | Swingline Office Equipment & Supplies
Staples will not come out of the stapler.
Did you use Optima brand staples? If not, the stapler will not work correctly. You must use their brand of staples or it will continue jamming, and giving you problems. The staples typically found right next to the Optima staplers in the office supply stores. They come in a rectangular metal box and are labeled Optima staples.
Sep 18, 2013 | Swingline Optima Electric Stapler 45 Sheet...
No staples coming out of machines
The Optima line of staplers do not work without jamming continuously unless you use the Optima brand staples. They can be found in the store next to the Optima staplers in a rectangular silver box, and will solve you problem instantly. There is no other brand of staple that will work in this line (I tried numerous), but once you purchase the Optima staples, problem solved, and you'll love it!
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
Optima Model # 8787x. Appears to be jammed. How do I open up the stapler to remove cause of jam. I think if I could open it up I could fix it. If all fails can this be sent away to be fixed and...
You need to open the stapler from the back. Push the black piece at the back of the stapler in, then pull it up and out. Remove the jammed staples, and reinstall. Make sure you use the correct staple . It appears to be: SWINGLINE 35550 HIGH CAPACITY STAPLES, 3/8"
Apr 13, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
Mar 10, 2010 | Office Equipment & Supplies
Swingline Optima Electric Stapler 45 Sheet Capacity Silver Logo
7,277 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Arnie Burke
Arnie Burke
Kenneth Walker
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
