Question about Pride Mobility Products Health & Beauty
Why does the bus not start
The bus is just cranking but not starting looks like edc but everything is ok.
Posted by barry on
Thomas Smithbrother
    Top Expert:
  • 3,698 Answers
Check for spark
Check for fuel.
check for compression.
If all the above work correctly then it is out of time.
Posted on Jun 13, 2014
04 1500 ram 4.7
Check your ground on the drivers side front of cylinder head or crank sensor could cause no communication.
Dec 27, 2014 | Cars & Trucks
ZBR failuer
Hello Muhammad. May I know where r u from ? Im from Malaysia. You can try to replace a new ZBR. I think it cost below RM1000 and send it back to MAN Truck & Bus for settings the ZBR.
Dec 20, 2014 | Bruder MAN TGA Container Service Truck
I have bus man lions coch year 2004.problem is edc 00637-01 wat is it
anti clock brakes either a sensor is faulty or you have air in the lines bad fluid {old} a master brake cylinder or its servo cycliders and or some ec {controller} connection is wrong in a bus i would expect a servo at each drum and a master cylinder does the air come up too speed when the engine starts ie does the pig cylinder charge and when charged bleed its self to regulate the brake preasure i think its a sensor thats bad on one of the brake servos at the hubs ...
Oct 18, 2014 | Cars & Trucks
My 2000 jeep grand cherokee larado stalled at a red light yesterday just like some one just turn off a switch now gages arnt working right it wont start cranks strong but no spark no fuel presure fuel...
Fuel pump is good, but no fuel pressure? How did you determine that the pump is good?
The ff
Failing gages point towards a problem with the PCI data bus or the PCM itself. This takes quite some troubleshooting to find the cause.
There are many components connected to the PCI bus and any of them could bring the bus down. You can measure the voltage on pin 2 of the data connector on the left side of the drivers footwell area. A good bus voltage is around 2.5 V. There is a PCI bus disconnect plug under the steering tube. By removing the shorting cap, you will disconnect almost all components from the bus. PCM and SKIM will still be connected and you could try to run the engine. You will ot have instruments nor most of the other systems, but this is only to see if the PCM works ok. If it runs, then you will have to look which component or bus wire gives the problem.
Oct 31, 2013 | 2000 Jeep Grand Cherokee
2004 Sebring replaced starter. OK for 2 days. No starting. Set for awhile, Started. Happened again. Computer said "NO BUS" . Local mechanics stumped. Help please??
Sounds like you may have a bad ignition switch. The ignition has be on to read codes and the ignition must be turned to crank a starter motor
Oct 22, 2013 | 2002 Chrysler Sebring
2001 lincoln ls cranks but wont start
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 20, 2012 | 2001 Lincoln LS V8
2001 jeep cherokee want start
Dont worry about wire checks at this point. If the "no bus" message went away after disconnecting the sensor, then the sensor is bad. Replace the crank sensor and all will be good in the world again.
Jul 27, 2009 | 2001 Jeep Grand Cherokee
Engine starting problem
check to see if your trunk is locked to the far right. mine does not start when it is. 1996 c220
May 02, 2009 | 1996 Mercedes-Benz C-Class
2000 dodge durango
a bad cam or crank sensor can cause a no start and a no bus meessage in the cluster if the are shorted. if possible try unplugging them one at a time and see if the no bus message disappears
Nov 23, 2008 | 2000 Dodge Durango
Health & Beauty Logo
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
