Question about Casio FX-115ES Scientific Calculator
Is it possible to find chi squared? If so, how?
Posted by Trend ell on
Chi square
Chi-squared distributions: http://en.wikipedia.org/wiki/Chi-squared_distribution
Chi-squared test: http://en.wikipedia.org/wiki/Chi-squared_test
Or do you have some other question in mind?
Oct 28, 2013 | Cars & Trucks
I want to do a chi-square test on the TI-85
The chi-square test is used for a lot more than just contingency tables.
I found one program for the TI-86 (which is basically the same machine as the TI-85, only with more memory) which claims to do the chi-square goodness of fit test.
You might also want to browse through this archive.
Nov 29, 2012 | Texas Instruments TI-85 Calculator
There are several applications missing on my ti-84. I don't have tcdf, chi squared cdf, or chi squared GOF test. How can I get these on my calculator?
Those functions are in the DISTR menu, accessible by pressing 2ND [DISTR].
If you need any of them, you can download apps from
http://education.ti.com/educationportal/sites/US/productDetail/us_ti84p.html?bid=7
Apr 07, 2011 | Texas Instruments TI-84 Plus Calculator
How do you find out chi squared on a casio fx 9860G SD calculator?
The following screen captures are from another Casio Graphing calculator so the menu screen may not look yours. However the instructions are identical.
Here is a sequence of screen captures to illustrate how to do it.
Turn calculator ON. Use arrow to highlight STAT and press EXE
Press F5 DIST
Then select F3 CHI
Choose Cpd or Ccd
If you choose Cpd : you must enter the Chi value you want, and press EXE, then the number of degrees of freedom (df) and press EXE. The Execute command is highlighted. This allows you to perform the actions
indicated by the Thumbnails at the bottom of the screen: calculate a value or Draw the distribution.
In the example above I took Chi=1, and df=3 and pressed the CALC menu.
If I press the DRAW menu instead, the distribution is displayed.
If you want the other distribution Ccd, press Ccd instead in screen capture 4.
Jul 31, 2010 | Casio FX-115ES Scientific Calculator
How do I look up chi square table on a casio fx-9750G plus?
Press F5 DIST
Then select F3 CHI
Choose Cpd or Ccd
Jun 21, 2010 | Casio FX-9750GPlus Calculator
I don't have a chi square goodness of fit test, where can i find?
You can find the chi-square test for two-way tables and the chi-square goodness of fit tests in the STAT TEST menu (STAT Left).
You can find the chi-square probability density function in the DISTR menu (2ND [DISTR])
Mar 31, 2009 | Texas Instruments TI-84 Plus Silver...
Casio FX-115ES Scientific Calculator Logo
198 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
