Always when am trying to put the usb in it doesnt show it,i wonder if there cud be any help i can get in order to get the right drivers for it
The drivers are normally part of windows system and as such are not needed, but if you are still with XP, then that may be the issue as support for XP has totally finished as the unit is so old it is now "end of service life" which means Acer do not support the unit for any reason as well, unfortunately i don't know of anyone who might be able to help unless you do try Acer tech and see what help they might be able to offer.
SOURCE: I want USB port Driver for detect
No mention of Brand of Pen Drive so I would start there first.
Try www.pendrive.com
Also no mention of when the latest updates were done ,hmmm
Normally should auto recognise when plugged in
(should do anyway)
When you install usb drive,
and drive does not appear be present,
SOLUTION...............................................................
Assuming your using XP,
go to start
then my computer,
right click,manage,
disk management,
This will put you in the area where you can check the health and activitys of your hard drives,
If this drive was recognised in the port then it will be visable in this area,
here you can right click on the drive and update the individual drivers of each device that may have issues.
So go ahead right click and update the drivers,
click I have disk on the wizard prompt and let the wizard search for the correct drivers,
if it comes back saying please insert cd then let the wizard search the internet for the correct drivers.
If this does not fix the problem then a Factory Default Reinstall will fix this.
If the issue still remains after these steps its the motherboard replacement time.
BACK UP BEFORE FORMATTING.......
SOURCE: downloading
if u wanna download to desktop use right mouse click on link and use save as.. and choose the place to download desktop
SOURCE: I reinstall VISTA on my laptop(ACER 6920)
Acer erecovery looks for the hidden partition as it is used for restoring the system back to factory defaults. If the hidden partition is not available, the software will not install.
Nothing to be worried about. You will not even need that software.
SOURCE: Can u help please re my acer laptop aspire
some pen drives and memory sticks need drivers to get connected to computer
Get online
and got to www.google.com In the google search box type: "Dell
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Bluetooth drivers.
You can always purchase a usb bluetooth adapter that will solve the problem at Tiger Direct.
http://www.tigerdirect.com
In
the search box at the top of the webpage type Bluetooth USB Adapter and
press GO. Sort the returned results Price Low to High.
