Question about Sony Ericsson Genuine Ba700 1500mah Battery For Xperia Neo Mt15i Kyno V Mk16i
How to factory reset my sony ericsson xperia - Sony Ericsson Genuine Ba700 1500mah Battery For Xperia Neo Mt15i Kyno V Mk16i
2 Related Answers
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: Repairing (replacement) Sony Ericsson XPERIA X1 LCD Display
All these videos below will help u in ur task
http://www.youtube.com/watch?v=pO2GSMb3aWM
http://www.youtube.com/watch?v=RHMKchQeOdQ
http://www.youtube.com/watch?v=V0sOaIo6724&feature=related
Pls RATE ME WELL !
Posted on May 28, 2009
Anonymous
SOURCE: i have sony ericsson xperia x1, i have forget my
go to sony ericsson website then update your phone software but since you can not open your phone all data that were saved in your phone will be deleted but then your phone again.. it's up for you to choose.
Posted on Apr 13, 2010
3helpful
Need to reset sony ericsson xperia 10x cell phone
The Sony Ericsson Xperia X10 is highly customizable and you have been hard at work tweaking it to your liking, but now the fun is over and you want to return it to its factory settings again.
Here, we show you how to hard reset the Sony Ericsson Xperia X10 with step by step instructions.
Please note that all data will be deleted from the Sony Ericsson Xperia X10 as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
1. From the main home screen, tap menu
2. Tap Settings, then SD card & phone storage
3. Tap Factory data reset
4. Tap Reset phone
5. Enter your password, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
2. Hold the Left and right buttons located beneath the display
3. Press and release the Power button
4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X10. Once the wipe is complete, the phone will reboot to its factory fresh state.
Regards.
1helpful
1ST IS : 1-Turn off your Sony Ericsson Xperia
2-Remove the battry and replace it back in
3-Press anda hold down the left and right silver buttons just under the screen
4-With the stylus,press in the hole on the right side of tehe battery
5-After 10 seconds,you will be prompted to press the R key on your silide-ou keyboard
6-If successful press the Space Key on your slide-out keyboard to finalise changes 2nd IS :
1 From the Xperia 10 Home screen, tap the applications bar.
2 Tap Settings > SD card & phone storage > Factory data reset > Reset phone.
3 Enter your screen unlock pattern.
4 Tap Erase everything.
Done! Now, You can reset your Xperia X10 to its factory default settings.
This is a soft rest its never hardrest, pls we someone to give haedrest solution,-even when there is password, which can be removed easiy
1helpful
Locked out of sony ericsson xperia
completely power phone off.hold the power button down until a reset screen comes on and then choose reset to factory settings.
3answers
I can't start my phone and need to doo a complete reset. How can i do it? Thanks Regards
How to hard reset the Sony Ericsson Xperia X8First, try this:
  2. Tap Settings, then Privacy
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
2helpful
2answers
Phone locked Need to reset Dont know how
Heres how to reset without access to the phone.
Good Luck, second time someones asked for this model tonight so i had answer on hand!
2helpful
I cannot send text messages from my sony ericsson vivaz u5i, but i can recieve text messages, incoming calls and i can make outgoing calls.. what is the factory setting code so i can reset my phone?
First, try this:
  4. Tap Reset phone
The password is user defined, try the second method if you did not set a password.
Good Luck!
Hello. I tried to reset my new Sony Ericsson Xperia X10 in line with he user guide. I went from Settings to SD Card & Phone storage settings, but from there I cant find the 'Factory data Reset' option...
I can't remember my gmail account information and I am locked out of my xperia phone from too many pattern attempts. No combination I try will work.
Try to enter password as null. If didnt worked means do a hard reset . You will get factory settings enabled after resetting.
Sony Ericsson Genuine Ba700 1500mah Battery For Xperia Neo Mt15i Kyno V Mk16i Logo
Top Sony Ericsson Computers & Internet Experts
Tom Chichester
ADMIN Canada
ADMIN Canada
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
