Question about Logitech LX7 Cordless Optical Mouse
File"p5vd2vms.rom"not found on cdrom - Logitech LX7 Cordless Optical Mouse
connect a 2nd mouse and visit the Logitech website. let the utility there discover your device and install the proper software.
Jun 13, 2014 | Logitech LX7 Cordless Optical Mouse
M2n-mx bios problem
try new cmos battery
Feb 13, 2014 | Computers & Internet
How to burn a file to compact disk
First you will need to check whether your CD-ROM or DVD-ROM support writing to disc. It can be found in the manual of your CDROM or your computer. Something like DVD-RW (R stands for read and W stands for write). Then you can use a DVD or CD burner software there are bunch of them online or you can use some integrated with the operating system such as Windows XP.
A free one available on the following link.
http://cdburnerxp.se/
Oct 11, 2010 | Computers & Internet
Only get File "k8NEB.rom" not found on cdrom
hi, its prasant, dont worry ,you do one thing, u cange your sata cable ,and check your power cable which come from SMPS . i think that will do ,and if not,mail me, [email protected]
Jun 23, 2009 | ASUS K8N-E Motherboard
Dvd-cdrom plays music-cd.Not dvd-cd :No Valide Drive/Disc Found
Simply change the ROM to DVD RW drive since this is an old PC and now days nobody uses a dvd rom but a dvd writer. It will be worth it since it can do all the functions and is also more hardy........sodeep
Apr 29, 2009 | Compaq Presario 7599 (173952-004) PC...
How can I transfer a document from Works to a cd?
It is very easy. Just right click on your document file and select SENDTO, after that, select your CDROM
this operation will burn your document into your CDROM directly.
Don't forget to insert a BLANK CD into your CDROM, before doing this process.
Feb 25, 2009 | Microsoft Windows Vista Home Basic for PC
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Hp pavillion dv1000 cd rom drive
memphisrains -
Sounds as though you may need to reinstall the driver for the laptop's cdrom drive. The easiest way I've found to do this is to download it directly from the manufacturer's web site; In your case, look here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-31831-1&lc=en&cc=us&dlc=en&product=435618&os=228&lang=en
Download the file to your desktop (file name is sp30367.exe), and run the installation to reinstall & update the DVD/CD-ROM drivers.
Hope this helps!
-thinstatic
Jun 10, 2008 | HP Pavilion dv1000 Notebook
Rom bios error
turn off your comp.,go to cmos setup,go to boot option,make your cdrom as the first boot device.insert the support cf of your mboard to cdrom to recover the original rom bios because your bios file was corrupted already.dont turn off your comp, while flashing.
May 19, 2008 | EPoX EP-4PEA+ Motherboard
Open Questions:
Logitech LX7 Cordless Optical Mouse Logo
Top Logitech Computers & Internet Experts
Ekse
Marvin
Marvin
Thomas F. Schneider
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
