Question about Fossil Big Tic JR7896 Watch
What is the button for, the watch works fine, the button does nothing
Posted by Guy Willis on
Thomas Smithbrother
    Top Expert:
  • 3,698 Answers
Www.youtube.com/watch?v=LlC2gqvfuAI
Posted on Jun 13, 2014
How do you "unfreeze" a champion c9 wrist watch?
I am having the same problem. The battery is fine, the seconds are ticking away, but none of the side buttons work. The light doesn't come on and nothing happens with any of the others either. The only thing that did work was pressing all four of the buttons simultaneously, which seemed to totally reset the watch. The problem is it reset but didn't fix the buttons. So now I can't even see the correct time anymore.
Nov 21, 2014 | Geneva Watch Group C9 by Champion Mens...
How can I "unfreeze" the digital readout on my timex WR 50m watch?
You may need to remove the battery and then reinstall the battery. Then there is a small spot on the movement that you touch while simultaneously touching the top of the battery. This will reset your watch. Somewhat like rebooting your computer.
Oct 19, 2011 | Watches
My wife has a Nike Alpha Project watch with new battery. We cannot set the time. I press "Mode" and nothing happens. I hold it down and nothing happens. Perhaps the buttons do not work? Shawn
Maybe the button is not pushing the internal button properly. Undo the back and remove the watch unit from it's case and then see if it works when you press the internal button.
Aug 02, 2010 | Watches
Watch is working fine but the chronograph is not
sounds like it needs to be serviced under warranty. The clutch mechanism maybe jammed or broken.
Apr 26, 2010 | Sector 2653940025 Wrist Watch
Setting analogue time on a Crane & Viceroy Radio controlled watch
I haven't been able to locate your watch but since watches tend to be similar in operation, I suggest that you look at the instructions for my watch and try a similar settings.
Go to "http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf" and instructions for a Casio watch will appear. Go to page 4 and read instructions under "to adjust analogue time".
Mar 30, 2010 | Watches
Ul 1008 analog portion does not work
Are the hands moving but out of step with the digital display?
If so then try pressing the "mode" button to reach a mode that allows you to set the hands (on my Casio it is "HS"), I would expect something similar on yours.
You can then alter the hands by pressing one of the other buttons. I would expect one button to advance the hands and another to ****** them.
Happy experimenting!
Feb 22, 2010 | Kenneth Cole Watches
I have a Luminox Navy Seal Watch. It has worked fine for about 6 or 7 years. I noticed that the minute hand seems to stick and then release about 4 seconds at a time. Is this something that needs to be...
Obviously you never noticed this before. Do nothing, as there is nothing to fix. This is normal behaviour sooner or later noticeable on all quartz watches.
Rate me, plz.
Jan 11, 2010 | Watches
Vivani watch has multiple dials and buttons but no response
Yeah I have the same kind of watch. The three small dials are ornamental and nothing more (this is obvious because their denominations are 60, 60, and 24, instead of something useful like 1-12 month, 1-31 for date, and 7 days of week). The extra two spring buttons are probably the same... nothing but ornamental. You could verify this by taking the back off the watch and seeing for yourself that they probably press nothing at all. Are simply there for maybe some other design where the case is uses,to illuminate the dial or other thing not on the watch. Vivani watches seem to be simple watches that are very ornamental and pretty (i.e., dress watches on the cheap) but completely lacking in features at all.).
Apr 16, 2009 | Watches
Fossil Big Tic JR7896 Watch Logo
232 people viewed this question
Top Fossil Watches Experts
john h
Lisa Christine
Lisa Christine
Bill Boyd
Are you a Fossil Watch Expert? Answer questions, earn points and help others
